Pontiac GTO Fog Light LED Bulbs! Several Bulb Models! Plug & Play Install! - Pontiac GTO Forum
post #1 of 16 (permalink) Old 10-16-2015, 08:50 AM Thread Starter
Supporting Vendor
Diode Dynamics's Avatar
Arrow Pontiac GTO Fog Light LED Bulbs! Several Bulb Models! Plug & Play Install!
(G8 used as comparison)
We carry LED bulbs for replacement of your GTO's fog lights, in all major sizes. They are available in HP, XP, and XML2 styles.
Just simple plug and play, replace the bulb and you are good to go!
We carry the brightest, highest-quality bulbs at the lowest prices. Your order will ship same day, and we're here if you need us for support and service. And we do not raise the prices to astronomical levels- We're breaking that market trend, and offering you great, low prices, every day. These LED bulbs are designed by us here in St. Louis, and every bulb carries with it a three-year limited warranty.
Diode Dynamics offers several brightness options so you can choose what fits you best. These options are listed by the design and the lumen output of each bulb, compared to the factory bulb.
Brightness:
HP48: 265 lumens. Slightly lower brightness than factory.
XP80: 510 lumens. Similar brightness to factory.
XML2: 1410 lumens. Much brighter than factory. These are bright!
*XML2 is available in 3000K Yellow / 4000K / 5000K / 6000K Color Temperatures
Bulb Design:
HP48: This bulb is designed with 48 Epistar 3014 LED chips. Thanks to the cap on the top, the light from this High Power Bulb is shined backwards and away from the bulb, not straight out. This means the output is excellent, because it uses the vehicle's housing completely, which then shines the light much more uniformly.
XP80: Each of the four sides of this bulb contains three 5W-rated chips, and the top is fitted with four more, under a projector lens. This is the brightest self-contained automotive LED bulb on the market, and is housed in an aluminum casing with a textured finish for maximum heatsinking properties.
XML2: NEW! Two opposing genuine CREE XM-L2 chips, driven at high power by self-contained regulator unit, in an attractive cast-aluminum housing. Fully waterproof, non-polar, modular design.
These bulbs are made up of a quality plastic connector to slide right into the plug, as well as high durability terminals. A load resistor is embedded to prevent blowing the LEDs from voltage surge, and a diode is implanted to protect the LEDs from reverse polarity. The LED is wired for 12V operation, the kind found on all modern vehicles.
Included in your order is TWO BULBS (to fit your Pontiac GTO).
All of our products come with a 30-day satisfaction guarantee and a 3-year limited warranty.
Click below for more info or to order:
2004-2006 Pontiac GTO
If you have any questions, please don't hesitate to post, PM, email contact@diodedynamics.com or call: (314) 205-3033
*PM us for the free-shipping code* (U.S. forum members only)
Thanks for looking!
Nick C.
Diode Dynamics is offline
post #2 of 16 (permalink) Old 03-24-2016, 02:59 PM Thread Starter
Supporting Vendor
Customer Submitted photo with Yellow XML2 Installed
Nick C.
post #3 of 16 (permalink) Old 03-27-2017, 10:02 PM Thread Starter
Supporting Vendor
PM responses sent
post #4 of 16 (permalink) Old 03-28-2017, 06:46 PM Thread Starter
Supporting Vendor
Visit our site to learn more: Diode Dynamics
post #5 of 16 (permalink) Old 03-31-2017, 10:46 AM Thread Starter
Supporting Vendor
(314) 205-3033
post #6 of 16 (permalink) Old 04-02-2017, 09:24 AM Thread Starter
Supporting Vendor
post #7 of 16 (permalink) Old 04-03-2017, 09:12 PM Thread Starter
Supporting Vendor
PM responses sent!
Nick C.
post #8 of 16 (permalink) Old 04-04-2017, 06:24 PM Thread Starter
Supporting Vendor
Our dealer locator tool has been updated, check it out to find a dealer near you:
Diode Dynamics Dealer Locator Map
Thanks!
Nick C.
post #9 of 16 (permalink) Old 04-06-2017, 12:03 PM Thread Starter
Supporting Vendor
post #10 of 16 (permalink) Old 04-07-2017, 11:58 AM Thread Starter
Supporting Vendor
Send us a PM to receive the free-shipping code
*U.S. members only
Thanks!
Nick C.
  Pontiac GTO Forum > Supporting Vendors > Diode Dynamics
Human Verification
Pontiac GTO Turn Signal LEDs! Plug & Play Install! No "Hyperblink" w/Flasher Module! Diode Dynamics Diode Dynamics 14 Yesterday 06:04 PM
Pontiac GTO License Plate LEDs! Plug & Play Install! Same day Shipping! Diode Dynamics Diode Dynamics 16 Yesterday 03:42 PM
Pontiac GTO Reverse/Backup LED Bulbs! Plug & Play Install! Ships Same-Day! Diode Dynamics Diode Dynamics 25 Yesterday 01:36 PM
Pontiac GTO LED Conversion Kit! Upgrade your lighting! Plug & Play Install! Diode Dynamics Diode Dynamics 13 Yesterday 09:47 AM
Dashboard issue with tail light LED install 6LGTO Interior Discussions 6 08-28-2014 08:57 PM
