Pontiac GTO Turn Signal LEDs! Plug & Play Install! No "Hyperblink" w/Flasher Module! - Pontiac GTO Forum
post #1 of 27 (permalink) Old 10-16-2015, 08:34 AM Thread Starter
Supporting Vendor
Diode Dynamics's Avatar
Lightbulb Pontiac GTO Turn Signal LEDs! Plug & Play Install! No "Hyperblink" w/Flasher Module!
Pontiac GTO Turn Signal LED Bulbs
From the factory, turn signal bulbs are powered by standard incandescent lights that light up amber or red in color.
Newer luxury vehicles are using LEDs for turn signals, because LEDs offer a crisp, instant on/off, increased brightness, and true, vibrant color. By replacing the bulbs in your GTO, you can achieve this modern look!
Resistor Option: The Pontiac GTO will hyperflash when LED bulbs are installed as turn signal replacements. We offer a resistor kit option to remedy this issue.
LED Flasher Option: To stop hyperblinking, you can replace your flasher module with this one, designed for LEDs. If you purchase this, resistors are not needed. Only one needed for your GTO
We carry the brightest, highest-quality bulbs at the lowest prices. Your order will ship same day, and we're here if you need us for support and service. And we do not raise the prices to astronomical levels- We're breaking that market trend, and offering you great, low prices, every day. These LED bulbs are designed by us here in St. Louis, and every bulb carries with it a three-year limited warranty.
Diode Dynamics offers several brightness options so you can choose what fits you best. These options are listed by the design and the lumen output of each bulb:
Brightness:
HP48: (280 lumens) Similar brightness to OEM bulbs
HP11: (310 lumens) Slightly higher brightness than OEM bulbs.
XP80: (510 lumens) Much brighter than OEM bulbs. These are bright!
Lumens: BUYER BEWARE! Most sellers just provide "calculated" lumen numbers, based on the maximum potential brightness of the LED chips on the bulb. For example, if a bulb has five 10-lumen chips, they will rate it at 50 lumens. However, this is not accurate, as the design of an LED bulb does not get rid of heat fast enough to run the LEDs at maximum.
These "calculated" lumen ratings are much, much higher than the true, measured light output, so it will look like competitors' bulbs are brighter than ours. This is because Diode Dynamics does not provide inflated "calculated" numbers; we believe it is misleading. We test the actual brightness of the bulbs in our lab, to provide real lumen output measurements. Our measurements are accurate, but they are usually much lower than the misleading "calculated" figures.
Fitment. All three bulbs use a quality aluminum 1157 terminal, with a standard base connector and proper pin alignment, designed for exact replacement of your factory 1157 bulb.
Front Turn Signal LEDs for 2004-2006 Pontiac GTO
Rear Turn Signal LEDs for 2004-2006 Pontiac GTO
Tail Light LEDs for 2004-2006 Pontiac GTO
Any questions, feel free to ask via email (contact@diodedynamics.com), Post or shoot us a PM!
*PM us for the free-shipping code* (U.S. forum members only)
Thanks,
Nick C.
Diode Dynamics
Diode Dynamics is online now
post #2 of 27 (permalink) Old 10-16-2015, 01:42 PM Thread Starter
Supporting Vendor
Meet our newest LED bulb replacement, the HP48:
Available in 1156/7 - 3156/7 - 7440/3 sizes
post #3 of 27 (permalink) Old 02-15-2017, 01:29 PM Thread Starter
Supporting Vendor
How to Install Resistors for LED Turn Signals & Fix Hyperblinking - Diode Dynamics
post #4 of 27 (permalink) Old 03-28-2017, 08:25 AM Thread Starter
Supporting Vendor
Visit our site to learn more: Diode Dynamics
post #5 of 27 (permalink) Old 03-31-2017, 04:15 PM Thread Starter
Supporting Vendor
(314) 205-3033
post #6 of 27 (permalink) Old 04-03-2017, 12:42 PM Thread Starter
Supporting Vendor
PM responses sent!
Nick C.
post #7 of 27 (permalink) Old 04-04-2017, 10:23 AM Thread Starter
Supporting Vendor
Our dealer locator tool has been updated, check it out to find a dealer near you:
Diode Dynamics Dealer Locator Map
Thanks!
Nick C.
post #8 of 27 (permalink) Old 04-06-2017, 04:50 PM Thread Starter
Supporting Vendor
post #9 of 27 (permalink) Old 04-07-2017, 03:34 PM Thread Starter
Supporting Vendor
Send us a PM to receive the free-shipping code
*U.S. members only
Thanks!
Nick C.
post #10 of 27 (permalink) Old 04-11-2017, 08:50 AM Thread Starter
Supporting Vendor
PM responses sent!
Thank you,
Nick C.
  Pontiac GTO Forum > Vendors > Diode Dynamics
Human Verification
Pontiac GTO License Plate LEDs! Plug & Play Install! Same day Shipping! Diode Dynamics Diode Dynamics 29 Yesterday 09:55 PM
Pontiac GTO Reverse/Backup LED Bulbs! Plug & Play Install! Ships Same-Day! Diode Dynamics Diode Dynamics 39 Yesterday 06:40 PM
Pontiac GTO LED Conversion Kit! Upgrade your lighting! Plug & Play Install! Diode Dynamics Diode Dynamics 6 Yesterday 01:26 PM
65 GTO brake lights, Turn Signal, and Flasher urall8s 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 9 10-10-2010 08:14 PM
Turn Signal Fuse keeps blowing after radar detector install HotRodGuy Service, Maintenance and Technical Discussion 13 02-28-2006 10:30 PM
