15 Inch Tire options? - Pontiac GTO Forum
post #1 of 9 (permalink) Old 11-11-2011, 10:20 PM Thread Starter
My 71 needs some new rubber eventually.
I have 15 Inch rally 2's and was wondering what everyone runs in 15 inch tires.
Pics would be great.
Probably going to run Radial TA's..but sizing options and other suggestions appreciated.
Thanks.
XCELERATIONRULES is offline
post #2 of 9 (permalink) Old 11-12-2011, 07:14 AM
jigaway's Avatar
I have a 71 as well. Right now she has 235/60/14s. There is 1.5" room between the tire and fender. I bought two 15x7" Rallye IIs for the back in hopes of getting the rear end up a tad giving the car a more aggressive look.
I would like a touch wider tire in the back so am thinking 245/60/15s in the rear. I think 255s would be pushing the width.
I have seen 235/70/15s and they look super.
Dan
jigaway is offline
post #3 of 9 (permalink) Old 11-12-2011, 12:06 PM
Quoted: 4 Post(s)
Thanks.
What is the width of the wheels? 6, 7 or 8? I run redlines on the 66 and TA's on the 67.
05GTO is offline
post #4 of 9 (permalink) Old 11-12-2011, 07:06 PM
15X8 Ralley with 5" backspace (custom) and run a 275 60 Radial T/A. I would certainly measure up before you order, but this will fit, handle, ride superb and really fills out those wheelwells. There is a ton of room in there with the right backspacing of the wheels.... And a little massaging of the the outer lip by rolling the fenders if neccasary . I run a 12.5 X 29 ET street with no rub so it can be done (thats with a 9.5" wide rim btw)
Gone....but not forgotten....
post #5 of 9 (permalink) Old 11-13-2011, 12:56 AM
Quoted: 34 Post(s)
I've got 15x7's on my 69, and I just put a set of 245/60-15's on it. They clear fine, and are very close to the same overall diameter as the original G70-14's.
post #6 of 9 (permalink) Old 11-13-2011, 09:22 AM
Hot_Rod's Avatar
My Lemans has futura 255 60/r15's all the way around. The fronts rub just a hair when you make hard, fast and sharp turns but theyre fine for the most part. Plus my suspensions worn smooth out so it sits a lil lower than it should.
They're the best bang for the buck tires you can get in 15's IMO. They ride good.
Jarred "Hot Rod" |1970 Pontiac LeMans Sport | Just a 350...
Hot_Rod is offline
post #7 of 9 (permalink) Old 11-13-2011, 08:35 PM
My GTO has 235/60/15's on 15x7 in the front and 245/60/15 on 15x8's in the rear:
More pics here:
http://www.cardomain.com/ride/3900019/1970-pontiac-gto
...I prefer the same size tire all around and may go with the same combo as my Monte when I'm due for tires (245/60/15 on 15x7 all around). I really like the look of the 255's all around that Hot Rod posted above too.
Kevin's Homepage
1970 Pontiac GTO
Orbit Orange Judge Re-creation / YZ RAIII 400 / M21 4-Speed
1985 Chevrolet Monte Carlo SS
5.7 LITRE / TES Headers / SShaker Hood / WCT5 5-Speed
85_SS is offline
post #8 of 9 (permalink) Old 11-14-2011, 11:28 PM
69Goatee's Avatar
I fit a set of 295's on the rear of my 69. I'm not sure if they are 50 or 60 series. They are on a set of 15x7 Cragar draglight wheels. I will have to dig em out of the shed to get the exact measurements. They had less than 1/2" clearance on the inside, and about an inch on the outside. The only time they rubbed was when I was drifting the car(was on a turn with a second gear scratch) and it caught traction, the left rear caught the inner wheel well and took a few chunks of rubber off. A bfh would fix that issue. They are BFG radial T/A's
1969 GTO
NUMBERS MATCHING
PAWN SHOP FIND
1947 MGTC
GRANDFATHER STARTED
RESTORATION IN 1980...
NIN
69Goatee is offline
post #9 of 9 (permalink) Old 11-15-2011, 11:23 PM
kilkm68's Avatar
My '68 Has 235/60/15 on the front and 255/60/15 Goodyear Eagles on the rear on Crager S/S mags. I'd like to go a little bit wider on the rear tires, I look into it if you can fit 295's under it.
kilkm68 is offline
Human Verification
Wheel/tire size options SWGOAT Wheels and tires 0 11-08-2011 10:53 PM
Tire options for the spare rim Poncho Dan Wheels and tires 1 03-18-2011 01:49 AM
285/30/18 tire on a 9.5 inch wheel? G T Oh Damn Wheels and tires 7 02-09-2010 06:07 AM
Stock tire options GimpsGTP Wheels and tires 7 08-28-2009 07:32 AM
15/10 inch rim how big of a tire can i go? 1969gtojohn 1964-1974 Tempest, Lemans & GTO General Discussion 2 05-07-2008 02:41 AM
