67 Front Brake Conversion - Pontiac GTO Forum
Pontiac GTO Pontiac GTO Forum
» Auto Insurance
Register Home Forum Active Topics Photo Gallery Garage Search Today's Posts Mark Forums Read Auto EscrowInsurance
Old 10-09-2012, 11:40 AM   #1 (permalink)
cdon's Avatar
I am getting ready to redo my front end (bushings, tie rods) and thought it would be a good time to convert my front drum brakes to discs. There are no salvage yards in my area that have a donor car. I currently have a power booster with a dual piston MC. I’m looking at this kit, 1964-72 Chevy, Pontiac, Buick, Oldsmobile, GM A Body, Front Stock Spindle Disc Brake Conversion Kit 19110 for $340.00 from performance online. It’s about an hour drive, will save shipping. Has anyone had experience with this kit or performance online? I have a question about the brake lines. I will need a new proportioning valve to replace the existing metering block. Are there fittings or adaptors that I can use or do I need to replace the hard lines? Thanks in advance for your input.
cdon is offline   Reply With Quote
Old 10-09-2012, 12:51 PM   #2 (permalink)
My Photos: (12)
I don't have experience with the company, but looking at the kit on their web site, the parts appear to be GM factory parts. The only item not included is the proportioning valve. You've got options there. I'm not familiar with what the factory setup in 67 was for disc brakes with regard to the valve. You could go 'factory', or you could go with an aftermarket adjustable valve, like the one from Wilwood. If you go that route, you'd leave your metering block in place and install the valve downstream from the block in your rear brake line. That's what I did on my 69 when I converted to Wilwood 4-wheel disc brakes. I located the valve about halfway down the driver's side frame rail, tucked up inside it, spliced into the line. To do the job yourself you'll need tools to make double inverted flares on tubing and the associated fittings. I highly recommend practicing on pieces of scrap tubing first until you're sure you can get them right. You just get one chance on your brake line. If you get it "too short" you'll wind up having to replace the line, and getting to the section that goes up and over the rear frame crossmember usually requires separating the body from the frame a little bit to get clearance.
Garland, TEXAS
BearGFR is offline   Reply With Quote
Old 10-09-2012, 04:17 PM   #3 (permalink)
My Photos: (473)
with bear,
Here is one from Summit that should work;
http://www.summitracing.com/parts/CLP-PV-2/]
05GTO is offline   Reply With Quote
Old 10-09-2012, 07:50 PM   #4 (permalink)
I converted my 67 GTO to front discs using a kit from Stainless Steel Brakes and am very happy with the results. Going with a kit will minimize the trips to your local parts dealer but you will still have to do a good bit of fabricating for a tight-looking installation. The prop valve that 05GTO posted is the same one I used; finding a suitable mounting bracket was the challenging part. Get a top-quality double flaring tool like Matco or Imperial and some tubing benders and you'll be in business. I found it helpful to mock up the new brakelines using lead solder to get the bends right.
GMoney is offline   Reply With Quote
Old 10-10-2012, 08:15 AM   #5 (permalink)
SANDU002's Avatar
My Photos: (6)
Agree ^^. SSBC brake kit has been on my '67 for 5 years and no problems. I went ahead and also put in all new stainless steel brake lines OPGI.
67 Post Coupe,
69 RA III Judge
06 BOM, M6, 18's
SANDU002 is online now   Reply With Quote
Old 10-10-2012, 03:52 PM   #6 (permalink)
bobby326's Avatar
I used rite stuff for my conversion. I gotthe 4 wheel brake kit with stainless lines and drilled a nd slotted rotors. The gave me stainless braded front lines for free. Its a stock gm 4 wheel brake kit but it came with eveything u need install from booster to bolts. After i paintes the dust shilds spindles and the calipers it looks really good. Verry happy with kit and it cost about $1000 for eveything.
bobby326 is online now   Reply With Quote
Old 10-11-2012, 11:08 AM   #7 (permalink)
cdon's Avatar
Thanks for your replies. I was able to buy the same kit with drilled and slotted rotors and stainless lines on performanceonline’s eBay store for a few dollars more. Bear your on the right track. I talked to Wilwood and they agreed with you, will install an adjustable proportioning valve in line between the block and rear brakes. Need to practice my flaring skills. Bobby did the brake updates come after the photo in your signature?
Old 10-12-2012, 11:30 AM   #8 (permalink)
OP,hope you dont mind me jumping in...
I have this Prop valve: http://www.summitracing.com/parts/SSB-A0707-1/
but im not 100% clear on where it needs to go. I also dont have any type of distribution block, do i need one of those also??
I bought the Summit power front disc brake conversion but unfortunately the instructions are not very good!
tk421 is offline   Reply With Quote
Front Disc Brake Conversion Jim 1964-1974 GTO General Discussion 11 07-01-2012 08:14 PM
SSBC front disc brake conversion problem!!! 66problem 1964-1974 Tempest, LeMans & GTO Technical Discussions 24 12-29-2010 01:37 PM
First "big" project for the '68 - front suspension & disk brake conversion Jeff's Classics 1964-1974 GTO General Discussion 14 10-03-2010 02:45 PM
front disk brake conversion: alternate cars? yousaygo 1964-1974 Tempest, LeMans & GTO Technical Discussions 7 06-07-2010 10:11 PM
1965 Front Brake COnversion BajaGTO 1964-1974 GTO General Discussion 4 03-11-2006 07:10 AM
Powered by vBulletin® Copyright ©2000 - 2015, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.3.2
