68 2bbl 400 - Pontiac GTO Forum
post #1 of 12 (permalink) Old 04-25-2011, 08:56 PM Thread Starter
68goatragtop's Avatar
68 2bbl 400
I have one of these and i was jut wondering if it is possible to run 93 octane gas safely in this engine since it has a 8.6:1 compression ratio? (i am a little new to restoring)
68goatragtop is offline
post #2 of 12 (permalink) Old 04-25-2011, 09:11 PM
68greengoat's Avatar
Your engine will thank you......
SOLD.....
462ci, 4spd
Performer Intake, Mild Cam
Pertronix Ignitor III
68greengoat is offline
post #3 of 12 (permalink) Old 04-25-2011, 09:37 PM Thread Starter
haha ill take that as a yes thank you.
post #4 of 12 (permalink) Old 04-26-2011, 05:27 AM
With that compression ratio you should be able to run 87 octane, every penny counts.
Gone....but not forgotten....
post #5 of 12 (permalink) Old 04-26-2011, 02:03 PM
Quoted: 34 Post(s)
Yessir. It's always safe to give an engine MORE octane than it "needs".
However, the reverse is the path that leadeth to (engine) destruction.
post #6 of 12 (permalink) Old 04-26-2011, 04:05 PM Thread Starter
WEll thank you guys from your input i really appreciate it!
post #7 of 12 (permalink) Old 04-26-2011, 07:48 PM
jetstang's Avatar
There is no reason to run 93 octain on a 8.6-1 motor unless you have an advanced curve kit in it or are running a bunch of timing to it. If you have it at stock timing it will run just fine on 87. If it doesn't ping, it doesn't need better gas.
Burning rubber since 1982!!
jetstang is offline
post #8 of 12 (permalink) Old 04-26-2011, 08:11 PM Thread Starter
oh ok awesome thanks again!
post #9 of 12 (permalink) Old 04-26-2011, 08:15 PM
Thumpin455's Avatar
No need for 93, 87 will work fine just like Jet said. Its an added expense that isnt necessary. The only way it will ping is if it is full of carbon or oil leaking past the rings/valve seals. Ive run 9:1 455s on 87 without issue, so a 400 at 8.6 is no problem.
Thumpin455 is offline
post #10 of 12 (permalink) Old 04-26-2011, 09:22 PM
I don't know. I have a low compression 455 that seems to run much better on 91(best we have here) than it does on 87 and better yet when I run an octane boost with the 91. The motor was rebuilt right before I bought it. Bored .030 with a mild cam. No specs on the cam.
I guess my recommendation would be to run 87 and 93 octane and you decide what makes it run the best. Keeping in mind that 93 octane will not hurt a thing except your wallet......
SOLD.....
462ci, 4spd
Human Verification
1972 400 2bbl to 4bbl Conversion jpdog357 1964-1974 Tempest, Lemans & GTO General Discussion 13 10-31-2009 03:00 PM
1970 B-Body 400CID 2bbl...want more power!! xcmac26 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 7 05-24-2009 10:47 AM
67 gto 2bbl carb choke problem bnichols04 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 5 10-08-2007 10:04 AM
67 lemans 2bbl electirc choke? bnichols04 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 7 09-06-2007 09:03 PM
Advice - How to wake up my '72 400 2bbl jpdog357 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 5 03-30-2007 08:01 AM
