68 serial numbers - Pontiac GTO Forum
Pontiac GTO Pontiac GTO Forum
» Auto Insurance
Wheel & Tire Center
Register Home Forum Active Topics Photo Gallery Garage Search Today's Posts Mark Forums Read Auto EscrowInsurance
Old 03-12-2013, 12:09 PM   #1 (permalink)
My Photos: (1)
68 serial numbers
I know if I did not have the original engine for my 68, I would be interested in finding it. I recently saw an ad for a couple 400 blocks with the serial numbers 166496 and 650249. I know this is like a needle in a hay stack, but thought I would post them just in case. Matt
Matthew is offline   Reply With Quote
Old 03-12-2013, 01:58 PM   #2 (permalink)
68greengoat's Avatar
One of those numbers would need to match the engine unit number on your PHS to be the correct block. Like you said, a needle in a haystack....... Are you sure your current engine isn't matching? You can compare the engine vin to the cars vin. Last 6 digits of each would need to match... First I would verify if it's a '68 or not. If not, don't worry about the engines vin. The date code is cast by the distributor. Ex B248, 8 being the year '68.
SOLD.....
462ci, 4spd
Performer Intake, Mild Cam
Pertronix Ignitor III
68greengoat is offline   Reply With Quote
Old 03-12-2013, 03:13 PM   #3 (permalink)
My Photos: (1)
Sorry for not communicating effectively. My block serial number and VIN match. I was saying that if it didn't, I would be interested in finding it. That is like looking for a needle in a hay stack. Does that make better sense?
Date code for 166496 is I-15-7
Date code for 650249 is C-27-8
Old 03-12-2013, 06:56 PM   #4 (permalink)
You communicated just fine, Mathew. I just read your first post too fast and thought you were looking for the matching block.. My fault....... Nice that your numbers match.....
SOLD.....
462ci, 4spd
Old 03-13-2013, 05:22 PM   #5 (permalink)
My Photos: (1)
Hey, no problem. I already know two 68 VINs these two blocks don't match. I really only posted it to make record in case someone is searching the forum in the future. And let me be the first to say... I like the color of your car. Matt
Old 03-13-2013, 10:02 PM   #6 (permalink)
67GTOCoupe's Avatar
Every one in a while you read a story of a long lost engine finding its way home. Very nice of you to post the numbers up just in case. You never know!
67GTOCoupe is offline   Reply With Quote
Old 03-13-2013, 11:29 PM   #7 (permalink)
Red1970GTO's Avatar
Oh man, it can be worse than that. My GTO has spent her entire life the the metro area. I've traced her owners back to the very early 1980s in an attempt to determine what happened to her original mill. I'm currently stuck looking for a divorced guy who does not want to be found. Worse, none of the previous owners gave a rat's rectum if the car had the original engine or not, the best they can tell me is that they didn't replace the engine. The chances that the number matching block is just sitting in a garage somewhere waiting to be reunited with the car are zeropointzerozerozerozeroone...
Red1970GTO is online now   Reply With Quote
Old 03-17-2013, 12:56 PM   #8 (permalink)
Jeff's Classics's Avatar
Sort of on the same topic...if anyone is looking for their original 400 4-speed '68 WS code engine this one has been on Houston craigslist off and on for quite a while.
1968 GTO 400 engine
I've been looking for a good block to start building a replacement for my original numbers matching 400, but the price on this one is WAY out of line IMHO, unless you really want a '68 4-speed block and/or the VIN matches your car.
Later
Jeff
'68 GTO, 400/TH400, AC/PS/PB/PW, hideaways, Hurst dual gate
'72 442 'Vert, 350/TH350, AC/PS/PB/PW
'74 Corvette, 383/4-speed, 450 hp, restomod
'71 Javelin, 304/3-speed
Jeff's Classics is offline   Reply With Quote
Old 03-19-2013, 08:32 AM   #9 (permalink)
67 Basket Case Restorer
Too Many Projects's Avatar
My Photos: (27)
Are you in the local GTO club ? There are a few guys in there that may have lists and sources for engines to check.
Mitch
1967 GTO; Gulf Turquoise on Black, 4 speed, buckets FOR SALE
1967 Camaro ss/rs 350
1966 Chevelle SS 396
1970 Chevelle SS 396
1966 Corvair Corsa convert
1952 Chev 2 ton flat bed
1938 Chev coupe
Too Many Projects is offline   Reply With Quote
Old 03-22-2013, 09:54 AM   #10 (permalink)
1968 GTO 400 engine
Later
Jeff
That's the right block for mine, now only if the vin matched. My '68 started it's life in OK.
The way it's being sold is, if your '68 originally came with a WS block, his block will make it a numbers matching. Well, that's only half of the equation..... Would make my car period correct, at the very least. Not sure how important that is in my situation.........
I inquired about the vin, if I get it I'll post it up....
SOLD.....
462ci, 4spd
are these low numbers? 04black Engine Discussions 9 08-26-2011 01:12 PM
65 frame serial # location? pbertrand65GTO 1964-1974 GTO General Discussion 1 05-15-2011 07:18 PM
What numbers should I expect?? JaySwyzz Engine Discussions 13 06-18-2009 02:16 PM
chassis serial number? Indy1K 1964-1974 Tempest, LeMans & GTO Technical Discussions 5 07-07-2008 08:47 PM
Wheel damage - serial number ShoddyHog Wheels and tires 3 06-01-2006 10:02 PM
Powered by vBulletin® Copyright ©2000 - 2015, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.3.2
