73 GTO Carb comparission? - Pontiac GTO Forum
post #1 of 5 (permalink) Old 02-26-2013, 03:39 PM Thread Starter
Hey all Im running the 442 in my 73 GTO, the 400 ci with the quadrajet carb, I was looking at switiching to a edelbrock 4 barrel but my neighbor who is more intuned with older cars sais that the Quad is a way better carb. Any advise?
airdale171 is offline
post #2 of 5 (permalink) Old 02-26-2013, 04:00 PM
Quoted: 31 Post(s)
No contest. A well set-up QJet is hands down better than the Edelbrock.
post #3 of 5 (permalink) Old 02-26-2013, 05:43 PM Thread Starter
Well thanks for that, that's what my neighbor was saying to but said to check online as well,
post #4 of 5 (permalink) Old 02-27-2013, 06:49 AM
Indeed, if it's set up properly, the Q-jet is the better choice. Look into getting the one you have rebuilt and you'll be happy.
1969 GTO
Numbers matching 400 c.i.d.
Numbers matching TH400 w/stage 2 shift kit
Limited slip 3.23 gears
2 1/2 inch dual exhaust all the way back
Dual gate shifter out of a '68
Cragar Protech rims
etewald is offline
post #5 of 5 (permalink) Old 02-27-2013, 01:47 PM
Quoted: 31 Post(s)
More often than not, the biggest problem with any QJet will be the 'last guy who worked on it' --- who was trying out his brand new subscription to the 'secret trick of the month' club and thought he could "fix" all the "well known problems" with the carburetor.
Set up properly with all internal systems working like they were designed to, that carb is very tough to beat on a street engine. The only real limitatiions they have are the 800 cfm "ceiling" which makes them insufficient to adequately feed large displacement, high rpm, high horsepower race engines, and the small fuel bowl which makes having an adequate fuel delivery system of prime importance.
Human Verification
Ram Air carb Roger that 1964-1974 Tempest, Lemans & GTO General Discussion 3 03-06-2012 10:30 PM
carb Topkat 1964-1974 Tempest, Lemans & GTO General Discussion 8 08-23-2011 06:34 PM
what carb to use bobby326 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 4 07-11-2011 06:22 PM
'68 GTO: Which Carb??? SixTeight 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 3 04-24-2011 08:35 PM
What's this carb off of? HOGOAT 1964-1974 Tempest, Lemans & GTO General Discussion 3 04-10-2005 09:37 PM
