Well..... I picked it up last night after work. I spent a good long time visiting with the owner and learned a lot, and liked what I was hearing more and more - convinced that the guy really knows his stuff.
Then.....
On the way home I noticed oil pressure was zero -- Well, obviously it had pressure and I really knew better, so I figured they'd managed to disconnect the wire from the sending unit during the R&R since it's right there by the trans filler tube. No biggie.
This morning I went out to fix that.
Found the sending unit wire was pinched between the block and the transmission. Well, ok --- it's an irritation but still manageable.
I put the car up in the air.
That's when I found one of the trans cooler line fittings at the trans leaking - pretty bad.
That's when I noticed the trans had a factory pan on it instead of my chrome one with the drain plug.
Am I just snake-bit when it comes to transmissions in this car or what????
I can't decide if I'm going to be mad or just be defeated...
