Coolant Flow Direction - Pontiac GTO Forum
post #1 of 4 (permalink) Old 01-06-2017, 08:26 PM Thread Starter
DTM
All,
Installing a Vintage Air system and need to install an inline value. Which connection is the "output" on a '70 455? The rear 5/8" one on the drivers side head or the 3/4" on the waterpump housing. I am thinking it si the one on the head... Can someone please confirm...
Thanks in advance,
DTM
DTM is offline
post #2 of 4 (permalink) Old 01-08-2017, 05:11 PM Thread Starter
DTM
No one can answer this?
DTM is offline
post #3 of 4 (permalink) Old 01-08-2017, 05:46 PM
The water pump pushes coolant out to the heater core and the radiator. The port at the rear of the head is the return from the heater core.
Bill
Billybobracing is offline
post #4 of 4 (permalink) Old 01-09-2017, 06:25 PM
Quoted: 70 Post(s)
Well, here is what I found doing an internet search:
Coolant flows into the water pump thru the bottom radiator hose, into the block from the water pump, up into the heads, and then to the intake crossover (or heater core from the back pass side head), then back to the radiator via the top hose. Coolant from the heater core is returned to the water pump not to the radiator.
And this:
Hot coolant flows out of the nipple from the rear passenger side head. The return is on the timing cover.
Human Verification
Lower control arm direction mjc707 1964-1974 Tempest, Lemans & GTO Exhaust, Suspension, Alignment, Fuel Tank and Brakes. 0 03-05-2016 10:36 AM
Direction of 1969 Side Vent Installation? LibertyBlue69GTOConv 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 6 02-16-2014 11:32 AM
water pump impeller direction !! dgoat8u 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 3 11-09-2011 03:27 PM
67 GTO Convertible Resto Direction binaryartisan 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 4 10-26-2010 04:15 PM
which direction for amp gain? rolo06 2004-2006 GTO General Discussion 15 05-03-2006 07:37 PM
