Old 04-23-2008, 07:36 AM   #31 (permalink)
Moderator
My Photos: (16)
Originally Posted by ppurfield001 View Post
Rukee's simple methodology above worked for me in determining that I had a 3.90 gear ratio.
I just replaced a 3.90 with a set of 3.55s and couldn`t be happier. The car feels alot faster too as it seems to have longer legs between each gear and goes down the highway excellent.
Old 04-23-2008, 10:12 AM   #32 (permalink)
ppurfield001's Avatar
My Photos: (12)
Point taken -- with the close ratio four-speed and the 3.90 gear ratio, the time between shifts on my goat is very short. Any idea how much it would cost me to go to 3.55 gears from 3.90 gears if I got a mechanic to do the changeover for me? Thanks.
ppurfield001 is offline   Reply With Quote
Old 04-23-2008, 10:24 AM   #33 (permalink)
Moderator
My Photos: (16)
I would expect to pay about $300-400 with parts and labor included depending on which set of gears you go with. You can pick up brand new gears from $227. I bought the Richmans myself, though the ones I bought didn`t say "Richmond Gear is not recommended for quiet applications." like these do, mine run quiet.
Auto Parts: YG GM8.2-355 - High performance Yukon Ring & Pinion gear set for GM 8.2 in a 3.55 ratio. Yukon exclusively uses 8620 steel in all their Ring & Pinion sets for high strength and long life. They use the latest designs and manufacturing tech
Auto Parts: RG 49-0015 - Richmond Gear ring & pinion gear set for GM 8.2 in 3.55 ratio. Richmond Gear has long been a staple in the performance gear market place with products geared towards the racing market. Their gears are made strong to withstand
Old 04-23-2008, 12:02 PM   #34 (permalink)
My Photos: (12)
Thank you Rukee. I will investigate the parts supplier described above. By the way, in determining my current gear ratio according to your methodology, I also confirmed that my goat has posi-traction.
Old 04-27-2008, 05:56 PM   #35 (permalink)
CJD
Hi, I've got a 68 goat that I bought in Mid-Michigan and I am trying to find out what gear is in it. I read your response and I went out with a wire brush and I could not find the W/Y designation. Is it close to the pig or more outboard?
Thanks,
CJD
CJD is offline   Reply With Quote
Old 04-28-2008, 07:43 AM   #36 (permalink)
Moderator
My Photos: (16)
Thanks,
CJD
Welcome to the forums.
As described above, to find your rear end ratio jack up the rear off the ground and rotate the tires one full revolution(for a posi unit), count the # of times the drive shaft turns to make the tires roll over one full turn. If only one tire rolls(open rear end) then block the one wheel and turn the one tire over two full revolutions and again count the # of drive shaft turns for your ratio. If you had a 3.90 gear the drive shaft will turn over almost 4 full revolutions (3.9 times to be exact), if you had a 2.73 ratio then the drive shaft will turn 2 and almost three quarters revolutions for every time the tires turn over once. It`s a very effective way to find your ratio.
Old 07-24-2008, 05:40 AM   #37 (permalink)
rick3452's Avatar
Having the 390's taken out and the 323's put in my 66 next Tuesday.Looking forward after almost forty years of driving this car to cruising the highway. Thanks for all the great info!!! Rick
1966 GTO tri-power 4 speed competition-plus, Tubuler Automotive competition headers. 58 thousand miles. Owned since 1969
rick3452 is offline   Reply With Quote
Old 07-24-2008, 09:16 AM   #38 (permalink)
My Photos: (2)
Rick: You're gonna kick yourself for not putting in the 3:23's 30 years earlier!! You'll love 'em! Good luck with the swap!
Jeff
geeteeohguy is online now   Reply With Quote
Old 07-24-2008, 09:43 AM   #39 (permalink)
Moderator
My Photos: (16)
I know going from 3.90s to 3.55 was a world of difference in my `65! I just swapped out the rear gears in a `71 Challenger 440 six pack car from 4.10s to 3.54s and that guy is sooo freakin happy he almost kissed me.
Restoration pictures password is 'GTO'
Old 07-24-2008, 11:25 AM   #40 (permalink)
rick3452's Avatar
Thanks Jeff....
GTO a real tire shredder? 05GTO In the News 52 10-31-2007 02:09 PM
05 GTO vs 04 GTO - 3rd gear pull BLACK05GTO Racing and kill section 2 09-24-2005 05:24 PM
Muscle round-up: GTO, Mustang, Charger 05GTO In the News 1 07-27-2005 08:48 PM
Pontiac GTO again flexes its muscles 05GTO In the News 5 05-06-2005 10:25 AM
