hei vs electronic points conversion - Pontiac GTO Forum
post #1 of 6 (permalink) Old 11-08-2008, 08:56 AM Thread Starter
auburnconsulting's Avatar
anybody try either one? with hei what pcm do you need to use for a 389? stock indash tach work with either one?
auburnconsulting is offline
post #2 of 6 (permalink) Old 11-08-2008, 10:18 AM
Quoted: 20 Post(s)
HEI will not fit with a Tri-Power manifold.
A straight HEI will not need a PCM. Only a single 12v keyed supply and a tach wire.
I prefer to use the stock points distributor and coil and a 6AL MSD ignition box. I hide the MSD unit in between the inner and outer fender on a plate and then the car looks totally stock, but has the benefits of an electric multiple spark discharge ignition.
Bolting on a MSD 6AL will definitely 'Wake-up' your motor!
post #3 of 6 (permalink) Old 11-08-2008, 10:47 AM Thread Starter
thanks. what i meant by pcm is the little module in the distributor. i know fro the k-5 4x4 hei vs the g5 for the 350 vans there is a built in rev limiter
post #4 of 6 (permalink) Old 11-08-2008, 10:50 AM
Quoted: 20 Post(s)
Seriously, a point distributor with an MSD will out perform an HEI.
post #5 of 6 (permalink) Old 11-11-2008, 08:54 AM
dtroit's Avatar
i have a pertronix under cap breakerless setup on a 65 389 catalina motor it works fine and i also have an in-dash tach
dtroit is offline
post #6 of 6 (permalink) Old 05-03-2009, 01:43 PM Thread Starter
well got my hei also got the msd module with built in rev limiter for the hei lets see if we get stranded by points again of have the plug wires vibrate out of the cap. our roads are terrible in michigan. also my in dash tach works with the hei but did not work with the points???
Human Verification
Electronic ignition for OHC 6 hpipe 1964-1974 Tempest, Lemans & GTO General Discussion 4 09-10-2008 01:53 PM
Stock Shift Points A4 AndrewZPSU Service, Maintenance and Technical Discussion 5 06-23-2006 01:43 PM
Conversion plans finalized.... johnebgoode The Lounge 1 03-17-2006 07:09 AM
Jacking Points -Revealed!! diverdan Service, Maintenance and Technical Discussion 8 05-20-2005 09:23 AM
