HELP! Fuel leak - Pontiac GTO Forum
post #1 of 7 (permalink) Old 12-03-2009, 05:12 PM Thread Starter
HELP! Fuel leak
My 69 GTO convertible began leaking fuel today. It is coming from right rear top of tank, running down the frame rail just behind the right rear tire (above the tailpipe!). the books show a vapor return line and a vent hose, as well as the feed line coming from that area. It leaks intermittenly, after shut down, enough to cause a quick 10" puddle. Then stops. Other times I shut down, doesn't leak at all. Running better than ever, so doubt it is the feed line? Any idea how or what would cause the vent or vapor return hoses to leak? any help appreciated!
Flyboy is offline
post #2 of 7 (permalink) Old 12-03-2009, 06:39 PM
Quoted: 20 Post(s)
crawl underneath and see were it's coming from.....
post #3 of 7 (permalink) Old 12-03-2009, 09:53 PM Thread Starter
I did crawl under, and it is running down the frame rail, i cant feel anything on top of the tank, and cant really trace exact location it is originating from. I dont see any hoses or lines. I thought it may be something common. I will get on a lift and drop tank.
Flyboy is offline
post #4 of 7 (permalink) Old 12-04-2009, 08:15 AM
67 Basket Case Restorer
Too Many Projects's Avatar
If it's running down the frame, it may be the steel line on the frame. The rubber hoses are right near the top of the tank and most likely wouldn't let the leaking fuel get to the frame.
Mitch
1967 Camaro ss/rs 350
1966 Chevelle SS 396
1966 Chevelle Malibu
1970 Chevelle SS 396
1962 Impala SS
1952 Chev 2 ton flat bed
1938 Chev coupe
Too Many Projects is offline
post #5 of 7 (permalink) Old 12-04-2009, 09:12 AM
66tempestGT's Avatar
if it is a vent hose it would probably leak when it was full and parked on a tilt. it has a short piece of rubber then turns to steel. may be rusty.
66tempestGT is offline
post #6 of 7 (permalink) Old 12-07-2009, 04:41 PM
the `vent deal'
didn't they go to an odd lookimh fuel tank vent deal mounted behind the rear seat in `68 or`9?,,my `67 has one metal tube that loops into the trunk back out thru a rubber gromet(why they plumbed it that way i have no clue,doesn't DO anything)
and if it was a california car it may have had`smog stuff' that no other state required,i witnessed a loaded `65 Lemans Sport that had a AIR pump,or at least the brackets and the(new owner) said it did originally,,so,sounds like a plgged vent of some sort,maybe the tank is building pressure,,what gas cap was spec'd,,,,and as a point of note i have had the soft lines go bad(between the tank/hardline to motor) about every decade so i'd check those while you're under there,,,keep us posted
i'm typing without my glasses so if i mispelled a word or three read it over,,,eyesite,it's the second thing to go
somewhere in oregon praying for some good gas,cool weather and a two car length jump on ya!
Hammer is offline
post #7 of 7 (permalink) Old 12-11-2009, 04:08 PM Thread Starter
Thanks Hammer. You know, I did put a shiny new gas cap on it about a month ago. Bought it from Ames, so assume right one. Good place to start.
Flyboy is offline
Human Verification
Braided fuel line, does it leak? 72GTORed 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 8 10-23-2009 12:58 PM
New item - Auto Meter ecometer fuel mileage gauge - plug and play @ PFYC.com PFYC Interior Discussions 0 07-01-2009 10:29 AM
Honda FCX Clarity (2009) andykhol23 The Lounge 1 05-29-2008 09:57 PM
Choke problem? 66_goat 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 21 06-07-2007 10:21 PM
Computer guages (Autotap OBDII-CAN Diagnostic) MJGTOWISH 2004-2006 GTO General Discussion 3 12-03-2006 11:01 AM
