HMI Stage III - Pontiac GTO Forum
post #1 of 9 (permalink) Old 01-09-2017, 01:10 AM Thread Starter
Wickedgoat's Avatar
HMI Stage III
Is this a good choice for my '64? Anyone install on Their GTO? My '64 project just getting under way. Going to attempt to get 389 running with M-22...figure this is where I start
"Never, ever, scratch a tiger's balls with a wire brush."
Wickedgoat is offline
post #2 of 9 (permalink) Old 01-09-2017, 06:50 AM
Quoted: 57 Post(s)
I apologize for my ignorance, but what is this HMI Stage III as I have no clue.
post #3 of 9 (permalink) Old 01-09-2017, 10:41 AM
1968gto421's Avatar
Quoted: 20 Post(s)
Can't find it on Google.....Please enlighten us, Thanks.
1968gto421 is offline
post #4 of 9 (permalink) Old 01-09-2017, 10:48 AM Thread Starter
Wickedgoat's Avatar
Sorry, my mistake. Forgive me for I am very new to this. I was supposed to post UMI performance Suspension upgrade stage III. I've got a '64 GTO in the garage fresh pulled from a Tucson junkyard. The motor an transmission out of it. I am going to attempt to get it up and running before I attempt a full off body resto mod.
I was thinking the way to start would be with one of these kits. They about $3,000 so I was looking for advice or tips, or to see if anyone has gone down this road.
post #5 of 9 (permalink) Old 01-09-2017, 07:03 PM
Quoted: 57 Post(s)
UMI has a good product line. I have several of their suspension parts on my '68 Lemans project build. Quality seems good and they supply any needed hardware. The Stage III kit seems to be very complete and should really handle well. They seem to offer it in a 2" or 1" drop, did not see original height. I might go with the 1" drop over the 2." I don't know what the drop will do to tire/rim sizing choices should you want to go wide.
As noted, you must make sure your car has its original rear end as the '64 uses a different upper control arm bushing versus the '65 and up models. So confirm this before you order so you get the right stuff.
post #6 of 9 (permalink) Old 01-09-2017, 07:28 PM
1968gto421's Avatar
Quoted: 20 Post(s)
Haven't used UMI yet thought I plan to for their rear suspension braces ( 1968-1972 GM A-Body Control Arm Reinforcements/Frame Braces [4028] - $129.99 : UMI Performance, Inc. ).
I have used rear suspension arm and sway bar upgrades from Spohn, a company BearGFR has used on his GTO. I have been very impressed with the quality and fit of their products (made here in the USA in Pennsylvania; where I believe UMI may be housed, also. Spohn = ( 1968-1972 GM A-Body, Chevelle, Malibu | Suspension & Chassis Parts ).
Sounds like a good beginning for your GTO. Jim has provided some excellent little known advice for you.
post #7 of 9 (permalink) Old 01-09-2017, 08:04 PM
Quoted: 57 Post(s)
Yep, used the Spohn adjustable uppers as well, got a little of everybody on my car. Hotchkis is another good brand for suspensions. I did look and they have a kit as well, but about $1200 more as I recall, so no as good a deal as UMI in my opinion, but they are a quality company as many use them.
post #8 of 9 (permalink) Old 01-10-2017, 10:44 AM
Quoted: 52 Post(s)
Have used UMI roto-joints on quite a few builds, including a pair that were modded into a pair of oem boxed lwr control arms. Autocrossed my first T/A in the mid 80's & learned a lot about spring rates. Just am not a fan of "one fits all" coil springs from any suspension kit company, I'd do more investigating. On my A-body's, that I've spent the most time on perfecting the suspension to hook, they're set up more for straight line, & two of them, by rules can't run tubular control arms, so no input there. On UMI's pieces, I do like the fact they are quality materials & made in the USA. There is a bunch of cheap tubular arm suspension pieces that are just that cheap import junk.
post #9 of 9 (permalink) Old 01-12-2017, 02:26 AM Thread Starter
Wickedgoat's Avatar
Thank you everyone.
That helps me. I am still early in the game. My car was sitting in a desert junkyard for decades. I spent a couple of day cleaning the engine compartment. Today I had dust mask on and tore out the interior. It was all but disintegrated. Car looks great though. Very little rust. Going to pick up a four speed today. Due to constraints of time and money it will be slow process, but a decision has been made to get the car up and running first. Then consider restoration. I am seriously looking at the suspension kit though. Seems like this is go time for that.
Human Verification
HEI to Pertronix Ignitor III and Flamethrower III toxic 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 14 11-20-2011 12:49 PM
2 stage unlocking Cobra126 Service, Maintenance and Technical Discussion 3 11-14-2009 10:47 AM
Stage 3 STI? Aramz06 Racing and Kill Forum 49 09-11-2008 09:23 AM
ME vs SRT-4 stage 2 Chrisco Racing and Kill Forum 5 04-24-2008 08:28 AM
Stage 1 VS. Stage 2 cam LS2 - Light SpeedX2 Engine Discussions 0 09-27-2006 10:08 AM
