Master Cylinder one chamber empty - 1969 LeMans - Pontiac GTO Forum
post #1 of 7 (permalink) Old 09-24-2010, 10:42 AM Thread Starter
Hello,
I was replacing the master cylinder cap (with a new chrome one) when I noticed that the forward chamber of the cylinder had almost no fluid in it, while the rear chamber (closest to the firewall) was almost overflowing.
Is that normal?
It is a drum/drum no-assist brake system.
I only had the car for a few weeks. Still trying to figure things out...
costucu is offline
post #2 of 7 (permalink) Old 09-24-2010, 12:33 PM
Originally Posted by costucu View Post
Hello,
Is that normal?
no. refill it and see if there are any leaks. one chamber goes to the front and one goes to the back.
freethinker is offline
post #3 of 7 (permalink) Old 09-24-2010, 01:25 PM
Quoted: 4 Post(s)
Check the rubber hoses going to the front brakes,
05GTO is online now
post #4 of 7 (permalink) Old 09-24-2010, 01:34 PM
Jeff's Classics's Avatar
I've also seen master cylinders leak down the firewall, check for oilyness and/or peeling paint below the MC. Could be a leaking wheel cylinder or brake hose, as already mentioned.
'68 GTO, 400/TH400, AC/PS/PB/PW, hideaways, Hurst dual gate
'72 442 'Vert, 350/TH350, AC/PS/PB/PW
'74 Corvette, 383/4-speed, 450 hp, restomod
'71 Javelin, 304/3-speed
Jeff's Classics is offline
post #5 of 7 (permalink) Old 09-24-2010, 01:45 PM
the same thing recently happened to me, turned out to be a bleeder screw that somehow popped and leaked all the front resevoir fluid dry.
but that front resevoir pushes the front brakes, so definitely don't drive it with no fluid or soon you wont be able to stop!
GroundHog is offline
post #6 of 7 (permalink) Old 09-24-2010, 03:36 PM
jetstang's Avatar
Look for wetness on the inside of the tires, the one that is streaky wet has the bad wheel cylinder. If it was leaking out the back of the master cylinderr, the rear resevoir would be empty, not the front. If you can't find the leak, fill it up and pump the brakes and look for the wet spot. Wheel cylinders blow all the time, they are under $20 a piece for new ones, I don't rebuild them at all anymore.
Burning rubber since 1982!!
jetstang is offline
post #7 of 7 (permalink) Old 09-25-2010, 09:26 AM
67HOGOAT's Avatar
Had the same problem on a 66 Vette. Had to rebuild the master cylinder, the seals were bad. If no other leaks, may be the same problem.
Alex
67HOGOAT is offline
Human Verification
1970 power brake master cylinder skyman51 1964-1974 Tempest, Lemans & GTO Exhaust, Suspension, Alignment, Fuel Tank and Brakes. 0 06-17-2010 05:26 AM
Switch master cylinder Richtenb Drive train, suspension, alignment and brakes. 1 04-15-2010 04:57 AM
master cylinder question 66tempestGT 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 5 04-12-2010 07:35 AM
new master cylinder, rear brakes not working BlueMonkey 1964-1974 Tempest, Lemans & GTO Exhaust, Suspension, Alignment, Fuel Tank and Brakes. 7 10-21-2009 09:27 AM
Brake Master cylinder replacement. Musicmike927 1964-1974 Tempest, Lemans & GTO Exhaust, Suspension, Alignment, Fuel Tank and Brakes. 1 05-24-2009 06:57 AM
