New 1969 Judge Owner - Pontiac GTO Forum
post #1 of 22 (permalink) Old 02-15-2017, 03:25 PM Thread Starter
Quoted: 5 Post(s)
Hey, I was fortunate to pick up a 69 Judge last week. Old restoration and needs some TLC. I'm sure I'll have tons of questions. Here is my build sheets. Any idea why someone would order the 444 tach/speedo instead of the hood tach??
Happy to join you guys!!
Name:	ImageUploadedByAG Free1487193827.824697.jpg
Name:	ImageUploadedByAG Free1487193887.606236.jpg
Name:	ImageUploadedByAG Free1487193910.215315.jpg
nautoncall is offline
post #2 of 22 (permalink) Old 02-15-2017, 03:36 PM
Quoted: 5 Post(s)
the car looks very nice. good luck with your plans and ownership.
linden_gto is online now
post #3 of 22 (permalink) Old 02-15-2017, 09:06 PM
Roger that's Avatar
Option 444 does have a panel mounted tachometer but it also gives you the Rally cluster (engine instruments and not warning lights).
The Hood (option 471) could not be ordered with Option 444. So if the owner wanted the hood tach and have Rally gauges they would have to order option 484 (Rally cluster and clock) and Option 471 for the tach (hood).
Option 444= $84.26
Option 471 and option 484= $113.74
I would guess money is why.
389, transistorized ignition, and a power pack of 3 deuce carbs..... and she chews up other cars and 426 Mopars.
Roger that is offline
post #4 of 22 (permalink) Old 02-15-2017, 11:13 PM Thread Starter
Quoted: 5 Post(s)
Ahhh, now that makes sense. That's why on my option list it says 471 not available with 444!
Knew someone on here was an expert. Thank you.
post #5 of 22 (permalink) Old 02-19-2017, 12:45 PM Thread Starter
Quoted: 5 Post(s)
So the car has American Racing 18" wheels. Can you tell from my invoice what wheels came on the car?? Thinking of looking for more stock look.
post #6 of 22 (permalink) Old 02-19-2017, 03:28 PM
Quoted: 70 Post(s)
Stock would have been the 14 x 6 Rallye II's without trim rings. However, you can get 15 x 7 if you wanted to go a little bigger: Wheel Vintiques 60-573404: 60-Series Pontiac Rallye II Wheel Size: 15" x 7" | JEGS They also make a 15 x 8 if you want even wider.
post #7 of 22 (permalink) Old 02-19-2017, 05:35 PM
Wendt69's Avatar
Nice buy! Great people on here with tons of info.
Wendt69 is offline
post #8 of 22 (permalink) Old 02-19-2017, 08:12 PM Thread Starter
Quoted: 5 Post(s)
I may can't fit them on the upgraded brakes. I have to see. Took my first real drive today!! I love it!!
post #9 of 22 (permalink) Old 02-20-2017, 06:43 PM Thread Starter
Quoted: 5 Post(s)
So I have searched and no real answer. I know everyone hates the dreaded oil question. So I'm going to ask anyway.
My motor has been built (forged Eagle bottom end, big cam, etc). It makes around 500 hp guesstimate. So what oil?? Dyno...syn?? Rotella, Vr1?? 10/30, 5/40, 20/50??
Thanks.
post #10 of 22 (permalink) Old 02-21-2017, 10:30 AM
1968gto421's Avatar
Flat tappet cam or Hyd roller cam? The flat tappet would require ZDDP in the oil in larger amounts than the roller cam. You can use either synthetic or conventional, if FT and synthetic, might need a tad of ZDDP added. Ax for viscosity, the newer your engine re-build the better an oil like 10W30 would work. If you know the engine builder of this engine, he should know his clearances and what viscosity would work best. Bedsides us Pontiac folks, the Chevelle guys worry about this oil thing, too. To that end, I give you a link on oil from their site. It has great info from an engineer re: too much ZDDP, and much about oil. I had to print it to read it as the screen was blowing out my eyes.
https://540ratblog.wordpress.com/
Hope this helps and keep asking questions---we're here to help.
( I am ancient and was in my 20's when these cars were new...many did not like the hood tach as after slamming the hood a bunch of times, the tach would go way inaccurate or quit.)
1968gto421 is online now
Human Verification
1969 GTO Judge Goatman64 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 3 07-11-2016 06:46 PM
1969 Judge Find knucklehead12 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 8 10-15-2015 05:21 PM
1969 RA3 Judge Instg8ter 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 13 04-29-2012 12:38 AM
1969 Judge in Competition Reno'sGoat 1964-1974 Tempest, Lemans & GTO General Discussion 2 12-17-2004 01:37 PM
