oil leak - Pontiac GTO Forum
post #1 of 4 (permalink) Old 11-20-2012, 01:17 PM Thread Starter
RIP (12/27/60-7/18/15)
Topkat's Avatar
oil leak
Hi gang.
After a 20 mile drive the other day (150 miles on the motor now I discovered a teaspoons worth of oil on my drip pan. It was comming between the water pump and the front of the TC cover.
The lowest bolt and mostly the next one up on the passengerside.
This bolt wasnt loose per-sec, but i got almost a 1/2 turn out of it and less on the bottom one and it isnt leaking, yet.
I'm pretty sure there's no 'quick fix' besides a new gasket, tho I suspect at some point i'll having to replace the TC cover itself. It wasn't in the greatest shape to begin with. dam! KInda pitted and slightly eroded on some edges
Not something I want to do untill i have to.
Thanks for listening.
Happy Turkey Day All!!
Tk
Topkat is offline
post #2 of 4 (permalink) Old 11-20-2012, 02:45 PM
Quoted: 35 Post(s)
Hi TK, back atcha. The timing cover is probably your culprit, if the sealing edges are erroded. As you know, the front section of the oil pan gasket is a serivice part, and easily changed with the TC off. You can repair the cover with JB weld, provided it's super clean. Then coat the inside of it with Glyptal to prevent further electrolysis. My advice would be to finish other things on the car first that may be more pressing and continue driving it for awhile if the leak is not bad. The repair is a simple, single afternoon job.
post #3 of 4 (permalink) Old 11-20-2012, 06:57 PM Thread Starter
Topkat's Avatar
Thanks Geeter. So I can use JB weld to kinda 'build up' areas of the mating surface that maye be lacking?
Interesting. That stuff will hold up in that oily hell?
Amazing...
I do need exhaust pipes rather soon..... lol
thanks as always!
Topkat is offline
post #4 of 4 (permalink) Old 11-21-2012, 06:41 PM
Quoted: 35 Post(s)
Yes. Clean the areas really well, fill in and build up where needed, let cure, and paint over the JB and the rest of the inside of the cover with Glyptal. It'll get you by for a long time. Meanwhile, start looking for a cherry timing cover.....
Human Verification
oil leak 64lemans 1964-1974 Tempest, Lemans & GTO General Discussion 2 06-09-2012 08:25 PM
Gas leak. This is odd..... 68greengoat 1964-1974 Tempest, Lemans & GTO General Discussion 5 04-07-2012 08:20 PM
A/C leak... Poncho Dan Service, Maintenance and Technical Discussion 2 06-04-2011 03:00 PM
leak 04blueskys Drive train, suspension, alignment and brakes. 1 03-20-2011 02:33 PM
Oil Leak SLVR DOG 2004-2006 GTO General Discussion 1 02-01-2007 11:13 AM
