Power Brake Booster Hose - Pontiac GTO Forum
post #1 of 4 (permalink) Old 05-19-2017, 04:59 PM Thread Starter
1968gto421's Avatar
Quoted: 22 Post(s)
I'm putting an SMI Q-jet that I ordered on my'68 GTO to replace the dysfunctional Edelbrock that it came with. In the process I will need to replace the vacuum hose going from the carb to the power brake (PB) booster. I went to the local chain auto parts store and asked for PB vacuum hose, they handed me 5/16" gas hose?!?
What are you all using for PB booster vacuum hose and in what ID?
Thanks!!
1968gto421 is offline
post #2 of 4 (permalink) Old 05-19-2017, 06:55 PM
good gas hose will work fine. your nipple is either 3/8 or 5/16, but 5/16 works tight on 3/8 nipple so that is all right.
pontiac is online now
post #3 of 4 (permalink) Old 05-20-2017, 04:38 AM
GTOJUNIOR's Avatar
Quoted: 16 Post(s)
The early oe hose from the factory and or optional PBB kit was 11/32 light duty vac hose.
This is from a '66 and may apply to your '69...
Name:	BOOSTER KIT 5b.jpg
ID:	90913   Click image for larger version
Name:	66 GTO OEM PB Vacuum Hose (4).jpg
GTO Jr. - A.K.A. SPRINT 6
GTOJUNIOR is offline
post #4 of 4 (permalink) Old Yesterday, 12:23 PM
KowalskiCW's Avatar
Yup I'm using the same set up with my SMI. I've read that it's pretty typical.
69 Lemans
KowalskiCW is offline
Human Verification
Currently Active Users Viewing This Thread: 15 (0 members and 15 guests)
Power Brake Booster Seal??? utidad 1964-1974 Tempest, Lemans & GTO Exhaust, Suspension, Alignment, Fuel Tank and Brakes. 0 07-03-2012 05:34 AM
Brake Question - Power Drum Booster goatdriver66 1964-1974 Tempest, Lemans & GTO Exhaust, Suspension, Alignment, Fuel Tank and Brakes. 4 05-15-2011 11:28 PM
power brake booster throw... Instg8ter 1964-1974 Tempest, Lemans & GTO Exhaust, Suspension, Alignment, Fuel Tank and Brakes. 6 03-07-2011 10:15 PM
power brake booster replacement scy-co 1964-1974 Tempest, Lemans & GTO Exhaust, Suspension, Alignment, Fuel Tank and Brakes. 1 02-19-2011 08:19 PM
