Pontiac GTO Pontiac GTO Forum
» Sponsors
» Sponsors
Register Home Forum Active Topics Photo Gallery Search Today's Posts Mark Forums Read
GTOforum.com is the premier Pontiac GTO Forum on the internet. Registered Users do not see the above ads.
Old 01-20-2006, 11:14 PM   #1 (permalink)
Rear seal replace
I have my 350 out of the car and need to replace the rear seal, anyone have experience with this? I'm not planning on removing the crank.
It sounds easy, however, the old Chiltons manual I have mentions something about cutting one of the seals into three pieces.
gman26 is offline   Reply With Quote
Old 01-21-2006, 12:59 PM   #2 (permalink)
Verdoro 68's Avatar
My Photos: (10)
This is one of those jobs that's so labor intensive that it really pays to do it right. You could replace the rear main with a stock rope seal, but they don't contain asbestos anymore and it will most likely start leaking again. That said, I have a rope seal in my '68 that was installed in '98 and it still seals well. Next time I do it (and there will be a next time), I'm going to go with a BOP Engineering neoprene rear main seal. Search the forums over at performanceyears.com and you'll get lots of feedback on the seals. They work well, but it's imperative to follow the installation instructions to the hilt otherwise it will leak like crazy.
If you decide you want to stick with the rope seal, here's a link to the '68 service manual that should be of some help. Specifically, here's the page on replacing the rear main seal.
Hope this helps!.
Verdoro 68 is offline   Reply With Quote
Old 01-21-2006, 10:35 PM   #3 (permalink)
can I do this without removing the crankshaft?
thanks for the link and info!
Old 01-22-2006, 12:30 AM   #4 (permalink)
Verdoro 68's Avatar
My Photos: (10)
According to the service manual you can, but I've only done it with the crank out. Seems like it might be difficult to clean out the old seal and pack the upper seal well with the crank still in place.
If you mean replace the old seal with a BOP neoprene seal while the crank is still in place, I don't think it's recommended. They have detailed instructions available on their website.
Powered by vBadvanced CMPS v3.1.0
Powered by vBulletin® Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.3.2
