Pontiac GTO Pontiac GTO Forum
» Sponsors
» Sponsors
Register Home Forum Active Topics Photo Gallery Search Today's Posts Mark Forums Read
GtoForum.com is the premier Pontiac GTO forum on the internet. Registered Users do not see the above ads.Please Register - It's Free!
Old 11-08-2008, 05:01 PM   #1 (permalink)
Trouble with msd installation HELP!
I installed my msd kit wich included coil box and distributor. I then go to start the motor and for some reason everything runs good but ever 30 seconds it goes POP and just keep popping every 30 seconds then i go inside the car to turn in off and the car dosent turn off.... I turn the key to off but the car still runs. This is on a pontiac gto. What is going on? I was told maybe the distributor is bad but i just got in brand new from summit. Help please
1969gtojohn is offline   Reply With Quote
Old 11-08-2008, 08:43 PM   #2 (permalink)
My Photos: (16)
On the poping I would double check the firing order, and on the key, not sure why, and I don't have to do it anymore, but for a while I had to turn the key past 'off' to 'Acc' and then it would turn off. Don't know why.
Restoration pictures password is 'GTO'
Burn-out videos.
Rukee is offline   Reply With Quote
Old 11-09-2008, 12:10 PM   #3 (permalink)
the fireing order is perfect. The timing is all good
Old 11-09-2008, 04:46 PM   #4 (permalink)
My Photos: (16)
I think if you read the instructions it will mention something about a resister to put in the wire for externally regulated alternators or some sheet.
On the poping, it shouldn't be doing any.
Burn-out videos.
Old 11-10-2008, 08:25 AM   #5 (permalink)
dtroit's Avatar
My Photos: (6)
pull the +wire off the coil to shut it off my 68 camaro did the same thing i think you need a resistor installed like rukee said
dtroit is offline   Reply With Quote
Old 11-10-2008, 10:42 AM   #6 (permalink)
My Photos: (16)
Originally Posted by Rukee View Post
... and on the key, not sure why, and I don't have to do it anymore, but for a while I had to turn the key past 'off' to 'Acc' and then it would turn off. Don't know why.
Actually, thinking about it now, that having to turn it past 'off' stopped when I swapped out the battery and voltage regulator. Possibly a voltage regulator would do the trick?
Burn-out videos.
Old 11-10-2008, 12:16 PM   #7 (permalink)
Ok thanks im going to try and replace and add those. People are telling me there was a recall on the mallory distributor and that it could just be that because before the car would run just fine.
Old 11-10-2008, 12:22 PM   #8 (permalink)
My Photos: (16)
I have mine hidden and run the MSD with the stock distributor and coil and it works awesome, and it all looks stock.
Burn-out videos.
Old 11-12-2008, 07:38 PM   #9 (permalink)
It dosent say anything about a resistor anywere in the book. the car was running perfect before everything is installed correctly so im guessing the distributor is bad or the box. i dunno
Old 11-13-2008, 07:12 AM   #10 (permalink)
My Photos: (16)
Again, I would just put the points distributor and coil back in and run the MSD with the white wire to the points instead of the two wire harness to the electronic MSD distributor.
Burn-out videos.
Msd Coils 04YJ-GTO 2004-2006 GTO Parts for Sale (Pictures Required) 0 01-09-2008 08:13 PM
NEW PRODUCT: MSD Dashhawk tbyrne Service, Maintenance and Technical Discussion 6 02-11-2007 11:50 AM
XM Satellite antenna and installation GTOJon Interior Discussions 14 08-29-2006 06:24 AM
gauge cluster trouble marathonman Service, Maintenance and Technical Discussion 8 08-17-2005 09:22 AM
Heated Seats Installation – Detailed Instructions inside rworkman98 2004-2006 GTO General Discussion 8 04-06-2005 11:23 AM
Powered by vBulletin® Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.3.2
