turn signal switch replacement - Page 2 - Pontiac GTO Forum
post #11 of 14 (permalink) Old 04-04-2013, 12:33 PM
I bought a really nice puller from O'reilly's for like $14. I'll probably use it 2 more times ever, but at least it's in the arsenal now.
1969 GTO
Numbers matching 400 c.i.d.
Numbers matching TH400 w/stage 2 shift kit
Limited slip 3.23 gears
2 1/2 inch dual exhaust all the way back
Dual gate shifter out of a '68
Cragar Protech rims
etewald is offline
post #12 of 14 (permalink) Old 04-13-2013, 05:46 PM Thread Starter
gotyorgoat's Avatar
Ok, so I seriously screwed this up. I took the column apart into about 25 pieces and can not get it back together.
The very back retainer ring slides over a bump and then twists to the right. I can not keep it straight long enough to get everyuting else back on over it. Buy the time I thread the screw through the new switch, it has twisted back.
It doesn't have nitrous. It has cubic inches.
gotyorgoat is offline
post #13 of 14 (permalink) Old 04-13-2013, 11:28 PM Thread Starter
gotyorgoat's Avatar
Got it installed with a few extra pieces left over. Could not get the springs that go over the 3 bolts to work, so I left them out. Also left blinker only works when out of park. Also flasher did not line up with hole in column housing. Also, brake lights still don't work. Basically a big waste of time and money. You win some, you loose some.
post #14 of 14 (permalink) Old 04-15-2013, 01:41 PM
Quoted: 20 Post(s)
can you post pictures of the left over parts?
Human Verification
turn signal ???? 44070dart 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 2 08-26-2012 10:10 PM
1968 turn signal switch 68gtohawk8369 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 1 02-26-2012 11:10 AM
67 GTO signal switch replacement lam63 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 0 11-12-2011 09:00 AM
66' turn signal switch... Instg8ter 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 19 08-17-2011 09:37 PM
Mystery Turn Signal Switch Koppster 1964-1974 Tempest, Lemans & GTO General Discussion 7 03-22-2009 07:16 PM
