Water on driver side floor board. - Page 2 - Pontiac GTO Forum
Pontiac GTO Pontiac GTO Forum
» Auto Insurance
Old 09-23-2012, 09:29 AM   #11 (permalink)
joesweeting's Avatar
Thanks for the information. I used a shop vac to clean out the area. I entered through the drivers side vent area first and then removed the "chicken wire" and ran the vacuum from the windshield back to the bottom of the cowl drainage. Will work on it again Saturday.
Sent from my ADR6425LVW using AutoGuide.Com Free App
joesweeting is online now   Reply With Quote
Old 11-27-2012, 05:17 PM   #12 (permalink)
Could be solved.
I had the windshield replaced and resealed for $258.00 by the Glass Doctor. There was a couple damaged areas on the previous gasket. It was raining when I left work and had no water on the floor boards. I will run it through a car wash this weekend to verify.
Old 11-28-2012, 07:38 PM   #13 (permalink)
jetstang's Avatar
My Photos: (10)
Glad you may have got it! Mine ended up being rotted out under the front lower windshield mount, and I ripped the entire car apart for it. Congrats, you may have got off easy. BTW, my buddy owns that glass doctor, there, Niceville and Crestview, no, I couldn't get you a discount, lol..
Burning rubber since 1982!!
jetstang is online now   Reply With Quote
Old 12-02-2012, 04:44 PM   #14 (permalink)
Still leaking. I had very light surface rust and 2 small rust holes about half the size of a plastic tack. I brushed the loose rust off and only had the two small holes. The holes are below the windshield under the chrome. However, they are on the top of cowl and should drain with the rest of the water. I'll have to get my wife with a water hose to identify exactly were the water is coming from. It appears to be dripping some where above the fuse box.
Old 12-09-2012, 02:34 PM   #15 (permalink)
I had to use my phone's camera and my wife's reading light to look into the area where the vent goes. I found where the water was coming from. I removed the vent in the kick panel when I installed after market kick panels with speakers. I plan on getting a/c in the future and have already purchased the lap vents so I pulled the out. After watching the video on my phone it appears the vents are needed to direct the flow of water from the cowl area. Please correct me if I'm wrong.
Old 12-09-2012, 03:36 PM   #16 (permalink)
My Photos: (7)
cowl leak
On our '66, both sides were completely filled and hard packed- after cleaning, I had to repair rust, so when I made new pieces, I made a provision for water drainage- and some water does go into the front section of the rocker panel, but on the bottom of the factory seam, there is an opening for water drainage, and most all the cowl water dumps there. (there are openings down the length of the rocker panel also-make sure you don't seam seal those up or the rocker WILL fill with water). Best of luck to you. P.S. And yes, from all I've read, the top section of the vent DOES redirect the water, thus the reason for that "thick gum seal" around the perimeter of the vent housing. Also, if I remember correctly (it's been awhile), I had to fabricate some sort of baffle to replace the rotted one- that also re-directs the flow to the drain hole.
gjones is online now   Reply With Quote
Old 12-09-2012, 08:40 PM   #17 (permalink)
I imagine the passanger would have a similar issue, but I don't see water on that side.
What do the factory A/C cars have in that area to divert the flow of water?
Could I "Dynamat" the area to keep the water our of my car. The material I purchased to dynamat my vehicle was from Lowe's for roofing.
Any input is appreciated.
Joe
Hurst tranny bracket and cutting floor board SPCMarty 1964-1974 Tempest, LeMans & GTO Technical Discussions 9 04-07-2012 07:29 AM
WTB 04-06 GTO Driver side fender limosteve 2004-2006 GTO Parts for Sale (Price & Pictures Required) 5 03-13-2011 10:10 AM
Water Leak in Trunk & Rear Floor Partsguru1 2004-2006 GTO General Discussion 32 10-21-2009 11:06 AM
Water board demonstration 05GTO The Lounge 6 05-23-2009 09:30 AM
Passenger side water leak razorgto Interior Discussions 0 08-30-2006 11:16 AM
SEO by vBSEO 3.3.2
