1970 gto rear axle fit a in a 1967 lemans?? - Pontiac GTO Forum
post #1 of 13 (permalink) Old 07-25-2010, 08:07 PM Thread Starter
will a 1970 gto rear axle fit in a 1967 lemans both a 10 bolt axle
bnichols04 is offline
post #2 of 13 (permalink) Old 07-25-2010, 08:18 PM
jetstang's Avatar
The 70 rear is 5/8" wider per side than the 66/7. I found a 66 rear for my 70 and it sucked the tires right up in the wheelwell, go the other way and tires are in the fenders.
Burning rubber since 1982!!
jetstang is offline
post #3 of 13 (permalink) Old 08-03-2010, 07:26 PM Thread Starter
would the axle in my 67 lemans be considered a 8.2" gm axle? the tag on it is long gone
post #4 of 13 (permalink) Old 08-03-2010, 07:43 PM
Quoted: 4 Post(s)
If the diff cover is the same as the one pictured it is a BOP 8.2"
05GTO is offline
post #5 of 13 (permalink) Old 08-03-2010, 07:47 PM Thread Starter
was that the only option in 67 with a 326? could i tell by the vin or anything?
post #6 of 13 (permalink) Old 08-03-2010, 09:53 PM
66tempestGT's Avatar
no need for tags. just look at the shape of the cover. particularly the "dips" on each side.
Shane Doss
66 tempest
64 el camino
02 mullis dragster
66tempestGT is offline
post #7 of 13 (permalink) Old 08-03-2010, 10:40 PM Thread Starter
where can i get a lower ring and pinion ratio? all i can find is 3:55 and higher I just want to rebuild my stock unit but the gears are worn out causing a bang. not sure if i should but a used axle or rebuild mine?? cost plays a big factor here. i am using this to just cruze nothing crazy
post #8 of 13 (permalink) Old 08-03-2010, 11:12 PM
jetstang's Avatar
If you can find a highway gear single spin rear for a 66, it shouldn't cost but a couple hundred bucks, just a take out item. To replace the bearings in yours, I don't know, $500? Maybe less, may not be the gears. To rebuild your rear, new gears and Posi is about $1500. You can convert to a 66/7 Chevelle 12 bolt with a conversion U-joint, gain all the plusses of a 12 bolt, but keep the narrow-ness? of the early rear, that is bang for the buck your best bet.
jetstang is offline
post #9 of 13 (permalink) Old 08-04-2010, 11:34 AM
Quoted: 20 Post(s)
Randy's ring and pinion will sell you a posi carrier for any gear ratio you want. I ordered an Auburn unit, 3:55 gear set and an installation kit, works great.
post #10 of 13 (permalink) Old 08-04-2010, 12:07 PM
xconcepts's Avatar
I'm pulling the rear end off my 66 which is a 2.56 ratio right now and replacing it. Its not originally off a GTO but fit perfect, no tire rub. I will be selling it so if your interested let me know, shipping would be the only pain.
xconcepts is offline
Human Verification
67 gto rear axle swap LTGOAT 1964-1974 Tempest, Lemans & GTO Undercarriage, Frame, Transmission and Differential Discussions. 1 10-20-2009 11:51 AM
1967 Pontiac Lemans wrinkled rear quarter panel Bobfuria1988 1964-1974 Tempest, Lemans & GTO Complete Exterior Body 2 03-16-2009 08:44 PM
Will a 68-69 GTO front clip fit on a 71 LeMans? team39763 1964-1974 Tempest, Lemans & GTO General Discussion 1 10-02-2008 10:44 PM
GTO rear axle Redline Service, Maintenance and Technical Discussion 5 08-16-2004 12:42 PM
