Powerglide stuck in 2nd gear? - Pontiac GTO Forum
post #1 of 7 (permalink) Old 06-14-2017, 04:38 AM Thread Starter
ERIC60's Avatar
I have an issue with my 2 speeds Powerglide mounted on my GTO 65;
first of all, when the stick is in "drive" position, it's like in "neutral", nothing happens;
I have to pull down until "low" position but it seems I"m actually in "drive" position;
also, when I take speed, I don't hear neither feel the "clonk" noise for knowing I'm on second gear;
so,in others words, I can drive perfectly in "low" psition, but being actually in "drive" mode, and second gear;
"rear" is fine;
any comment will be welcome!
ERIC60 is offline
post #2 of 7 (permalink) Old 06-14-2017, 12:38 PM
64GTOConvertible's Avatar
Console or column shit? Sounds like a stretched cable?
64GTOConvertible is offline
post #3 of 7 (permalink) Old 06-14-2017, 10:19 PM
El Monte Slim's Avatar
A tiny bit of help...
It will probably be easier to research this problem if you know that the two-speed transmission in early model GTOs is not a Powerglide, it's a Super Turbine 300.
It's a completely different unit than the Chevrolet Powerglide unit.
Hope this helps.
El Monte Slim is offline
post #4 of 7 (permalink) Old 06-15-2017, 01:54 AM Thread Starter
ERIC60's Avatar
I was told it's a Powerglide but anyway, the thing is that the shift lever located on the floor console is loose between "Rear" and "Low" positions;
but I can manage to drive "normally" in "Low" position;
ERIC60 is offline
post #5 of 7 (permalink) Old 06-16-2017, 10:10 AM
1968gto421's Avatar
Quoted: 23 Post(s)
If you don't have a factory shop manual you need one. It shows diagrams and instructions for getting the cable properly adjusted. I don't have '65 manual but someone here might and post a pic of the pages dealing with this.
Ames has great stuff --- Ames Performance Engineering, Classic GTO Parts, Firebird Parts, and Full Size Pontiac restoration parts.
They have the manual--- https://secure.amesperf.com/qilan/Se...8070A5C5CF1E50
Hope this helps.
1968gto421 is offline
post #6 of 7 (permalink) Old 06-16-2017, 10:16 AM Thread Starter
ERIC60's Avatar
yeah, I got this manual and I'm working on the adjustment;
I noticed that the rod was wobling (too loose)
so I tighten the backlash but now the "drive" is fine but in "park" position I am like in neutral, not clutched!
maybe I went too far in my adjustment and I need to go back!
ERIC60 is offline
post #7 of 7 (permalink) Old 06-17-2017, 10:10 AM
1968gto421's Avatar
Quoted: 23 Post(s)
This is a very frustrating job, you have my best wishes. I am lucky that the console cable to trans works OK on mine but for how long? Hopefully it will work out for you soon.
Human Verification
68 gto 4 speed stuck in second gear! Help! mwinters 1964-1974 Tempest, Lemans & GTO Exhaust, Suspension, Alignment, Fuel Tank and Brakes. 7 11-02-2014 07:11 AM
into 2nd gear Nate Wheels and tires 12 06-16-2010 02:06 PM
66 gto 4 speed stuck in gear? auburnconsulting 1964-1974 Tempest, Lemans & GTO Undercarriage, Frame, Transmission and Differential Discussions. 30 03-11-2009 03:36 PM
Will not go into 2nd gear? crccobra 2004-2006 GTO General Discussion 7 02-14-2007 01:34 PM
Stuck in First Gear I Stall Automatics Drive train, suspension, alignment and brakes. 2 06-07-2006 08:19 PM
