Rear axle decoding help!!!! - Pontiac GTO Forum
post #1 of 9 (permalink) Old 05-18-2010, 07:04 AM Thread Starter
mp4life23's Avatar
I have been looking all over and I cant find any info on this rear end. When your looking at the rear of the vehicle this number 8LM G9208 is on the front right axle tube facing the engine. There is also a raised H with a what looks like a upside down 4 on the left side of the housing facing the engine and a raised symbol (*) and a raised C and D or a O facing the engine any help i would appreciate.
mp4life23 is offline
post #2 of 9 (permalink) Old 05-19-2010, 07:59 AM
67 Basket Case Restorer
Too Many Projects's Avatar
Need to get the casting number and date code off the center section. It should be facing the rear but may be toward the front if not Pontiac.
Mitch
1967 Camaro ss/rs 350
1966 Chevelle SS 396
1966 Chevelle Malibu
1970 Chevelle SS 396
1962 Impala SS
1952 Chev 2 ton flat bed
1938 Chev coupe
Too Many Projects is offline
post #3 of 9 (permalink) Old 05-19-2010, 09:05 AM
Quoted: 4 Post(s)
Sounds like Chevy Codes, see if you can ID the unit with these pictures?
Pontiac
Oldsmobile 8.5 12 bolt
GM 8.2 10 bolt (Chevy)
GM 8.5
05GTO is online now
post #4 of 9 (permalink) Old 05-19-2010, 09:22 AM Thread Starter
mp4life23's Avatar
ill look tonight what type of ribs do the gto/lemans have I think there converging
post #5 of 9 (permalink) Old 05-19-2010, 09:28 AM
Quoted: 4 Post(s)
That is correct, type P (Pontiac) converging,
Attached is a picture of a type C (Chevy) 12 bolt under my 67;
05GTO is online now
post #6 of 9 (permalink) Old 05-19-2010, 11:33 AM Thread Starter
mp4life23's Avatar
i can see you dont have a sway bar, I dont either witch leeds me to my next ? what are the two holes one on each side of the axle carrier that are below the axle looks like something bolts there
post #7 of 9 (permalink) Old 05-20-2010, 07:05 AM Thread Starter
mp4life23's Avatar
Well i can see that I have a GM 10 bolt 8.5 in my car. I looked up and i can see there was some fabricating done up to fit it in, so i guess thats good Right ???
post #8 of 9 (permalink) Old 05-20-2010, 07:26 AM
Quoted: 20 Post(s)
The rear sway bar mounts onto two bolt holes in the lower suspension arms.
GTOs did not come with them cause they were made for straight line speed, not handling.
post #9 of 9 (permalink) Old 05-20-2010, 08:18 AM
Not necessarily.......there were thousands of them installed in A bodies that would be a direct bolt in without mods. If it is from a Nova or ****** that had leaf springs, it may not be centered correctly. Maybe it has a coil over set-up or aftermarket 4 link. It's very difficult to guess what you have without pictures to see and evaluate.
Mitch
1962 Impala SS
1938 Chev coupe
Human Verification
New Rear Diff And Axle Carrier 06goatm6 Drive train, suspension, alignment and brakes. 1 03-11-2010 01:36 AM
Rear axle identification??? ylwgto 1964-1974 Tempest, Lemans & GTO Undercarriage, Frame, Transmission and Differential Discussions. 6 11-06-2009 08:40 PM
Rear Axle Replacement DaveH 1964-1974 Tempest, Lemans & GTO Undercarriage, Frame, Transmission and Differential Discussions. 2 12-18-2007 08:20 AM
Rear axle Broke Toro Toro Service, Maintenance and Technical Discussion 26 12-05-2005 11:32 AM
GTO rear axle Redline Service, Maintenance and Technical Discussion 5 08-16-2004 11:42 AM
