Leaking Convertible - Pontiac GTO Forum
Pontiac GTO Pontiac GTO Forum
» Auto Insurance
Wheel & Tire Center
Go Back   Pontiac GTO Forum > The 1964-1974 Pontiac Tempest, Lemans & GTO > 1964-1974 Tempest, Lemans & GTO Convertible Top, Interior, Glass and Trunk
Register Home Forum Active Topics Photo Gallery Garage Search Today's Posts Mark Forums Read Auto EscrowInsurance
Old 01-29-2013, 09:55 AM   #1 (permalink)
Leaking Convertible
I discovered some water in the trunk of my newly restored 65 convertible. This is my first convertible and am just finding my way around the top. I used a small hand sprayer and directed some water on the outside surface of the rear plastic window. When I looked in the trunk I could see water dripping from the corners where the rear drain trough changes directions and goes down over the rear inner fender. Before I had the top installed I made sure that all holes joins etc where thoroughly coated with body sealant. Obviously I missed something. Anyone out there have a similar problem, and if yes how was it corrected. I have not taken anything apart as yet. I hope that the rear of the top does not have to come off to access these two areas from the top side. Any information would be appreciated, Thanks
olde-goat is offline   Reply With Quote
Gear in this thread - Powered by O'Reilly Auto Parts
a LITTLE coolant leaking from my new 05 gto wfsrde Service, Maintenance and Technical Discussion 7 11-10-2012 08:57 AM
water leaking into car 67 GTO 1964-1974 Tempest, Lemans & GTO General Discussion 12 03-08-2012 09:51 PM
Leaking?! urblueyedcountrygirl Interior Discussions 9 03-08-2010 07:54 PM
Transmission Leaking Jim 1964-1974 Tempest, Lemans & GTO Undercarriage, Frame, Transmission and Differential Discussions. 2 03-18-2009 10:18 PM
06 leaking struts ridgegoat 2004-2006 GTO General Discussion 4 03-19-2007 08:25 PM
Powered by vBulletin® Copyright ©2000 - 2016, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.3.2
