Need help mounting 65 steering column - Pontiac GTO Forum
post #1 of 4 (permalink) Old 06-20-2011, 07:39 PM Thread Starter
onetwomany's Avatar
OK guys I'm about to mount the steering column in my 65 GTO. Not sure about hardware and brackets. I have the lower half of a saddle clamp and two nuts and one "L" shaped bracket. Am I missing something to complete the assy?
Maybe a "U Bolt that would drop down from the dash over the column?? Please help. Thanks in advance. Vern
onetwomany is offline
post #2 of 4 (permalink) Old 06-20-2011, 09:52 PM
crustysack's Avatar
you are missing 2 steering column support brackets (they 3/8" round rods that are about 8-10 inches long the end that attaches at the top (under the top of the dash at the firewall)has a flattened area with a hole for a bolt, the other end is threaded with a stop flange) these rods go into the steering column bracket that is part of the dash, and then the lower half of the bracket ( a separate piece)goes around the bottom of the column and onto the threaded ends and you put the nuts on to hold it in place. I took a piece of 1/8" rubber and wrapped it around the column where the bracket goes. I do not think the L bracket is part of the steering- if the bracket is actually a double bent L bracket (more like a stretched S) then that is for the radio
crustysack is offline
post #3 of 4 (permalink) Old 06-20-2011, 10:47 PM Thread Starter
onetwomany's Avatar
Thanks Crusty. I think you jogged my memory. There are two rods like you mentioned in my interior parts box. They must be for the column support. Back to the garage for more digging. Thanks bud, I owe you a cold one.
post #4 of 4 (permalink) Old 06-20-2011, 11:00 PM Thread Starter
onetwomany's Avatar
I got em! The rods come down and also support the clutch pedals and then the column can be mounted from below. Thank you sir.
Human Verification
67-68' Steering Column Dreamingmisfit03 1964-1974 GTO parts for sale (Price & Pictures Required) 2 05-07-2009 10:39 PM
69 Lemans steering column Jays69 1964-1974 Tempest, Lemans & GTO Convertible Top, Interior, Glass and Trunk 0 03-05-2009 10:48 PM
Black steering column and steering wheel (plastic) for 1968 GTO. CCLGTO 1964-1974 GTO parts for sale (Price & Pictures Required) 0 01-10-2009 09:50 PM
Need steering column Face 1964-1974 GTO parts for sale (Price & Pictures Required) 1 01-10-2009 01:17 PM
67 Gto Steering Column? Jon67Gto 1964-1974 Tempest, Lemans & GTO Convertible Top, Interior, Glass and Trunk 4 10-30-2006 02:54 PM
