Originally Posted by dcgoat
Does anyone have the following installed on their Goat? If so, what are your thoughts as I plan to upgrade the suspension real soon. I will give up some ride quality for better handling.
STB007 GTO BMR strut tower brace $169.99
HOT-2278 Sway Bars: Hotchkis Sway Bar Front & Rear Set $359.99
EIB-3897.320 Sway Bar: Eibach Anti-Roll Sway Bar Set - Front & Rear $335.00
SPRING & SHOCK COMBO: Koni Yellows with B+G Sport Springs $725.00
I think over all you would see more gain frm the spring/strut combo. In a strictly street use, I prefer just the struts. If you want more, than add the springs.
I'm frm the school of thinking that prefers heavier springs over thicker sway bars. The thinking is that we want independent movement of each wheel. By tieing them together with bigger sway bars, we lose some of that independence. But i would replace the bushings to a urethane and the endlinks.
