Hi!
I want to change my front wheel bearing and all 3 brake hoses.
The problem is, I have disc brakes from some other model year.
I'm not sure which bearing and brake hose will fit. Are there other bearings for drum and disc brakes? Because if I search at Rockauto the same SKF bearings are used on 66 to 72 GTO's, no matter if the car is equipped with discs or drums, only some other gaskets are available.
Here are 2 pictures of how it looks like now, maybe anyone can tell me which parts to use:
http://members.chello.at/cg-tuning/hose1.JPG
http://members.chello.at/cg-tuning/hose2.JPG
And here are the options I found from different model years:
1. More Information for DORMAN H73242 (Dorman H73242)
2. More Information for DORMAN H71319 (Dorman H71319)
3. More Information for DORMAN H66724 (Dorman H66724)
Do you think 1 and 3 will fit, but have only a different style? I think I need a hose with a thread on one side, is that correct?
And these are the front wheel bearings (SKF BR2 and BR6)
1. More Information for SKF BR2
2. More Information for SKF BR6
Thank you!!
Chris
Thank you!!
Chris
