67 GTO Aftermarket Disc brakes - Pontiac GTO Forum
post #1 of 7 (permalink) Old 04-25-2013, 11:55 AM Thread Starter
I have a friend that had front and rear disc brakes put on his 67 GTO... they installed a new master cylinder and a vacuum brake booster. The car does not stop like you would think one would with power disc brakes. They did not install a proportioning valve or a new distribution block. the master cylinder is a dual piston ( It has two reservoirs). anything I can check into?
novafreak69 is offline
post #2 of 7 (permalink) Old 04-25-2013, 12:22 PM
Indetrucks's Avatar
Really strange that there is no proportioning valve.
I just purchased a front kit for my 67 GTO and it came with the proportioning valve (it was NOT an option)
Other than that, is his booster hooked up to the intake for vacuum? Without vacuum to the booster, it will stop like $hit.
Indetrucks is offline
post #3 of 7 (permalink) Old 04-25-2013, 02:12 PM Thread Starter
Yes it is hooked to the vacuum... where does it say that the proportioning valve should go?
post #4 of 7 (permalink) Old 04-25-2013, 04:22 PM
Quoted: 20 Post(s)
I would say you need the proportioning valve, as they came with all the duel port master cylinders. The two lines from the MS go to the PV, then two lines one to each front tire, then one line (the larger one and the one facing the rear) goes to the rear.
post #5 of 7 (permalink) Old 04-25-2013, 04:36 PM Thread Starter
Thakx... Now I need to find one... lol
post #6 of 7 (permalink) Old 04-25-2013, 04:45 PM Thread Starter
Do not think a proportioning valve is needed for a 4-wheel disc application... The stock distribution block is in place on the frame rail... it provides equal pressure to all 4 wheels...
Product Info
I believe I may have a too small of a booster...or some other pressure problem.
post #7 of 7 (permalink) Old 04-26-2013, 11:13 AM
Quoted: 20 Post(s)
Very confusing that they are calling it a distribution block. Look at the bottom of the page, they list a Pro. Valve bracket.
Human Verification
67 gto metering valve on power disc brakes info please fiesta62 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 6 04-03-2012 12:09 PM
Disc brakes on 65 GTO billh 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 5 06-29-2011 02:54 PM
69 Pontiac GTO Rear Disc Brakes josemusclecar 1964-1974 Tempest, Lemans & GTO Exhaust, Suspension, Alignment, Fuel Tank and Brakes. 9 11-29-2007 06:32 PM
Disc Brakes gman26 Drive train, suspension, alignment and brakes. 7 10-28-2005 05:31 PM
