Brake lights not working - Pontiac GTO Forum
post #1 of 3 (permalink) Old 02-17-2013, 06:31 PM Thread Starter
gotyorgoat's Avatar
My turn signals work fine, but my brake lights are not working. I have tested the continuity across the switch at the petal and it seems to be working fine. I have also looked at the fuses which seem to be fine.
Does anybody have any advice on this? If it were a grounding problem, the turn signals wouldn't work either, correct?
I have heard everyting goes through the turn signal switch. Do I need to replace that?
Thanks.
It doesn't have nitrous. It has cubic inches.
gotyorgoat is offline
post #2 of 3 (permalink) Old 02-17-2013, 08:30 PM
check that the contacts on the fuse is not rusted, had same problem with mine and it was the ears on the fuse clips. The sockets are self grounding to the taillight housings so make sure all contact points (grounds) are clean also. Yes the wiring runs through the horseshoe harness in the column, thats the next thing to check.
Instg8ter is offline
post #3 of 3 (permalink) Old 02-18-2013, 09:58 PM Thread Starter
gotyorgoat's Avatar
Thanks Brian. I did sand down the contacts at the fuse panel last time that I tried to troubleshoot this problem. I guess that I have some more digging to do. I finally got the trunk pan put back together and the tail panel welded in so I am itching to take it for a drive but am pretty much limited to the neighborhood until I get the tail lights working.
Human Verification
interior lights stop working 02r1 Interior Discussions 13 06-12-2013 06:37 PM
Fog lights not working? bartelt05gto 2004-2006 GTO General Discussion 5 08-19-2011 11:17 AM
Brake lights stopped working kermit2136 1964-1974 Tempest, Lemans & GTO Exhaust, Suspension, Alignment, Fuel Tank and Brakes. 6 01-17-2010 07:30 PM
'66 Gto Middle Tail Lights Not Working take5 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 1 01-03-2010 01:12 PM
head lights quit working on my 66 nmiller5000 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 11 12-08-2009 02:54 PM
