Intake and Carb numbers - Pontiac GTO Forum
post #1 of 5 (permalink) Old 09-16-2010, 10:46 PM Thread Starter
I have a 67 400 HO 360 HP engine in my 67 GTO and some one placed a edelbrock intake and a Holley Street Avenger carb on it. I would like to take it back to stock and was wondering what the correct number intake and carb would be for the car. It is a four speed car. thanks Mike
mshidner is offline
post #2 of 5 (permalink) Old 09-16-2010, 11:10 PM
Quoted: 4 Post(s)
The quadrajet part number for a manual tranny is 7027263 and the manifold part number is 9786286, good luck with your search.
05GTO is online now
post #3 of 5 (permalink) Old 09-16-2010, 11:42 PM Thread Starter
Hello Randy, thanks for the help. Where would a person find this information? Was there a difference between the low HP engine in 67 and the HO engine for the intake and carb? Also did the 67 HO Ram Air have a different intake and carb then the mid engine HO? thanks for all the help.
mshidner is offline
post #4 of 5 (permalink) Old 09-17-2010, 06:37 PM
Correct Intake
First you need to know the build date of your car. It is on the spec. plate on the firewall. Then you will need to find and intake with the matching date. It should be before the build date. For example a build date or A227 would need an intake with a date code of L156 or within 3-4 months earlier than the A227. Then you just need to get a carb with the right part number for the year. Carbs were also dated. The 400 HO had a Rochester. They get pretty pricey when all original. Hope this helps. Good Luck.
400HO is offline
post #5 of 5 (permalink) Old 09-17-2010, 07:12 PM
Quoted: 4 Post(s)
Here are the 1967 part numbers for the carbs and manifolds, there were 3 HP ratings for the 67 GTO,
1967 Carburetor part numbers;
1967 Intake Manifold part numbers;
Name:	67 gto manifold.jpg
ID:	8676   Click image for larger version
Name:	67 carb numbers.jpg
05GTO is online now
Human Verification
Anyone using an Edelbrock carb on a Pontiac intake? Edelbroke 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 6 02-05-2010 10:22 PM
Intake and carb GTO'n'TRANSAM 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 3 02-15-2009 05:51 PM
Intake and Carb GTO'n'TRANSAM 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 9 02-02-2009 07:57 AM
New Intake - and Current Carb?? ThomasGTO 1964-1974 Tempest, Lemans & GTO General Discussion 5 01-23-2009 04:50 PM
CARB intake? thispecialk Intake and Exhaust Discussions 8 01-23-2009 11:19 AM
