Before & After - Cleaning Alum. Intake/389 GTO - Pontiac GTO Forum
post #1 of 15 (permalink) Old 01-10-2017, 04:28 PM Thread Starter
Roqetman's Avatar
Quoted: 8 Post(s)
I'd read several posts about the best way to clean an aluminum intake and just wanted to pass on my experience for those who are interested. Since my intake was off the car it was relatively easy to try several recommendations and not worry about making a mess on the engine. I tried several products including carb cleaner, Brake Klean, Simple Clean. I applied each product and then scrubbed the intake with both brass and stainless steel brushes. After all that, I still was not satisfied. Then I tried Eagle 1 Mag wheel cleaner for cast aluminum wheels. It sprays on as a foam. I let it soak at least 30 seconds and then scrubbed with a nylon brush. Rinsed with water and then repeated the same process all over again. I dried it with a clean cloth and then used compressed air to blow out all the nooks. Attached are my before and after pics. Hopes this helps fellow GTO enthusiasts!
ID:	85458   Click image for larger version
ID:	85466   Click image for larger version
ID:	85474   Click image for larger version
ID:	85482   Click image for larger version
Roqetman is offline
post #2 of 15 (permalink) Old 01-10-2017, 07:12 PM
Quoted: 67 Post(s)
Not bad. But, if you have a local engine builder nearby, glass beading the aluminum intake is the way to go.
Then get a clear topcoat designed for aluminum intakes and you'll be good.
post #3 of 15 (permalink) Old 01-10-2017, 07:31 PM Thread Starter
Roqetman's Avatar
Quoted: 8 Post(s)
I really didn't want to spend the $ for glass beading but it may not be that expensive. I have not priced it, any idea of the cost? Also, I am leery of rattle can clear coats for two reasons. They can yellow with age and may not be gas resistant. Can you recommend a good clear coat brand? Thanks!
Roqetman is offline
post #4 of 15 (permalink) Old 01-10-2017, 08:27 PM
rickmpontiac's Avatar
Quoted: 5 Post(s)
Looks great!
Sent from my iPhone using Tapatalk
rickmpontiac is offline
post #5 of 15 (permalink) Old 01-11-2017, 09:01 AM
1968gto421's Avatar
Quoted: 22 Post(s)
Looks great, and for those of us on a budget, it's a great way to go. Thanks for sharing your discovery.
1968gto421 is offline
post #6 of 15 (permalink) Old 01-11-2017, 09:47 AM
deanhickey's Avatar
Quoted: 8 Post(s)
Looks great at that price!
deanhickey is offline
post #7 of 15 (permalink) Old 01-11-2017, 09:51 AM
deanhickey's Avatar
Quoted: 8 Post(s)
Diamond clear bare metal formula should do the trick.
post #8 of 15 (permalink) Old 01-11-2017, 05:33 PM
Quoted: 67 Post(s)
Here is the Diamond Clear as referenced: Eastwood Diamond Clear Gloss for Bare Metal
I have not used the Diamond Clear, but it doesn't look bad, and looks to do the trick. I painted my brother's intake with simply a high temp clear. I know some clears yellow, but I felt it was still better than the intake oxidizing or picking up grease/gas stains and figured it might also clean-up better with an engine cleaner if it did get grungy.
Some people simply spray the intake silver. Eastwood also offers this: Aluma Blast Paint Aerosol 12 oz - Aerosol Paint - Acrylic Lacquer Paint - Eastwood
post #9 of 15 (permalink) Old 01-11-2017, 08:24 PM Thread Starter
Roqetman's Avatar
Quoted: 8 Post(s)
Thanks!
Roqetman is offline
post #10 of 15 (permalink) Old 01-20-2017, 06:26 PM Thread Starter
Roqetman's Avatar
Quoted: 8 Post(s)
Before & After - Intake cleaning/389 GTO Continued...
Well... after further thought and consideration I found a local shop and paid $30 to get my aluminum intake bead blasted. It looks like new, see pics. Anyway, this is a good comparison of cleaning an intake with cleaners, mag wheel cleaner as compared to bead blasting. In my opinion it was worth $30 to make like new!
ID:	85793   Click image for larger version
ID:	85801   Click image for larger version
Roqetman is offline
Human Verification
MAF cleaning and stock intake tube questions... pctek Intake and Exhaust Discussions 1 10-23-2010 04:10 PM
K&N AirCharger Intake Kits, '04 & '05 GTO, $20 Off pfyv.com 2004-2006 GTO Parts for Sale (Price & Pictures Required) 0 11-29-2005 09:17 AM
K&N AirCharger Intake Kits, 04 & 05 GTO on Sale pfyv.com 2004-2006 GTO Parts for Sale (Price & Pictures Required) 0 11-07-2005 11:15 AM
K&N AirCharger Intake Kits, 2004 & 2005 GTO At Ridiculously Low Prices pfyv.com 2004-2006 GTO Parts for Sale (Price & Pictures Required) 3 10-20-2005 07:16 AM
Spring Cleaning - Wash & Wax Wing_Nut Exterior Discussions 13 04-12-2005 09:44 AM
