WARNING! Do not send your engine to this hack!
Well after almost a year of waiting to get this engine back from Jim L. @ CVMS including tearing it back down to a long block to fix things like rusted tins, cracked hub, leaking timing cover etc. I again had noise coming from the rockers and since this was the third time I needed to go back in to adjust I decided to pull one of the Magnum roller rockers to see WTF was going on.
Evidently Jim just pulled whatever push rods out of his junk pile, the rod on the bottom in the pic is the proper rod, the other 15 were destroyed by the lift on the cam and just hammered into fragments.
At least one out of the 16 was right.
I ordered a new set from Comp cams, they arrived and I installed them yesterday and used a magnet to get all the fragments I could and changed the oil and filter.
Of course the damage has been done, I now have 2 pounds of oil pressure at idle and 20 pounds at 3,000 RPM.
500 miles on the engine and it is junk, thanks Jim thousands of dollars pissed down a rathole over 30 dollars worth of pushrods.
I wouldn't send a lawnmower engine to CVMS and at this point I don't know what I am going to do with this car since there are no more reputable Pontiac builders and I don't have another 7K to throw away.
If anyone wants this car click on my pics and make me an offer, I have over 60K into it and am done putting money into it.
