Flywheel resurfacing - Pontiac GTO Forum
post #1 of 5 (permalink) Old 06-13-2017, 10:11 AM Thread Starter
chadd925's Avatar
Planning on having my flywheel resurfaced since it's out, should I just plan on bringing my flexplate, clutch and hardware in together to be balanced? What should I be looking at $ to do this?
ID:	92153   Click image for larger version
chadd925 is offline
post #2 of 5 (permalink) Old 06-13-2017, 03:32 PM
Since material will be taken uniformly across the surface, no change in the existing balance will occur. If the flywheel was balanced before, it will stay balanced. I've never balanced one doing a clutch job.
Sent from my iPad using Tapatalk
1965 Pontiac Tempest Custom - 326 bone stock
RT-1 is online now
post #3 of 5 (permalink) Old 06-17-2017, 03:06 PM
Quoted: 35 Post(s)
If it came from a running/driving car and all was OK, I agree with RT-1. If you came across it at a swap meet, and it's an unknown used part, balance would be a good idea. It NEVER hurts to balance any rotating assembly.....I had my pressure plate balanced to my engine many years ago....and have never regretted it.
post #4 of 5 (permalink) Old 06-18-2017, 12:27 AM
My nickle
well .... those are some deep heat cracks ....
also .... your bevel on the outside edge of the flywheel is gone ... meaning your fly wheel is super close to its min thickness...
your disc has been slipping for a while .... your pressure plate is probably blue also ... and the disc glazed ... replace em ...
please post a picture of the flywheel bolt heads please ... and clutch disc and pressure plate...
Scott
BLK69JUDGE is online now
post #5 of 5 (permalink) Old 06-18-2017, 10:41 AM
Goat Roper's Avatar
Quoted: 60 Post(s)
I would mic the flywheel first before doing anything.
When you remove material it makes it lighter which changes the dynamics of your set up.
Since a new one is around 100 bucks I don't mess with worn out parts and I would replace it with a new pressure plate, flywheel and clutch plate.
I hate doing things twice especially pulling a tranny over 100 bucks.
Not worth messing with a marginal part IMO.
Goat Roper is offline
Human Verification
Resurfacing Rotors new Brake pads iwant2buyaGTO Service, Maintenance and Technical Discussion 8 06-03-2013 06:37 PM
Flywheel Replacement jtwoods4 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 5 03-24-2013 03:26 PM
flywheel balancing p1squally 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 2 06-09-2011 10:46 PM
Flywheel HELP TxSoldier6.0 Drive train, suspension, alignment and brakes. 4 05-23-2011 07:08 PM
