How to burp air out of radiator and cooling system? - Pontiac GTO Forum
 2Likes
  • 1 Post By bigD
  • 1 Post By 64GTOConvertible
post #1 of 4 (permalink) Old 02-15-2017, 09:32 AM Thread Starter
Roqetman's Avatar
Quoted: 4 Post(s)
I have repaired the original 4 core radiator on my '65 GTO/389. I've also replaced all hoses, radiator and heater, and replaced the water pump gasket and thermostat. My question is how's the best way to burp all the air out of the system? I'm using distilled water and since there may be major spillage on my garage floor... I'd like to top it off with anti-freeze as the last step to prevent a mess on the floor and not waste anti-freeze.
Roqetman is offline
post #2 of 4 (permalink) Old 02-15-2017, 10:24 AM
Here's quite a few Googled ideas.
https://www.google.com/webhp?sourcei...cooling+system
Roqetman likes this.
bigD is offline
post #3 of 4 (permalink) Old 02-15-2017, 04:29 PM Thread Starter
Roqetman's Avatar
Quoted: 4 Post(s)
BigD, thanks again for the info!
Roqetman is offline
post #4 of 4 (permalink) Old 02-16-2017, 07:59 AM
64GTOConvertible's Avatar
Quoted: 4 Post(s)
While there are some good ideas there, a 65 GTO cooling system is not rocket science. The rad cap is at the top of the cooling system and turbulence from the coolant flowing will cause air to bleed out naturally. BTW, unless you have an overflow tank there will be an inch or so of air at the top of the radiator when the engine is cold. And if you do have an overflow tank, pressure in the system will force trapped air through the tank.
All that bleeding nonsense is for newer cars that don't have the fill at the highest point of the coolant system...
anthony2 likes this.
64GTOConvertible is offline
Human Verification
Cooling System how cool can i get it? 05yjacket Service, Maintenance and Technical Discussion 6 01-30-2013 06:49 PM
Cooling system...I hope Eric Animal 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 2 08-08-2011 11:55 AM
Cooling system capacity Poncho Dan Service, Maintenance and Technical Discussion 1 06-06-2011 08:56 AM
Cooling System: Opinions Please & Thank You Koppster 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 10 04-17-2011 11:34 AM
Radiator Cooling Fan Jermaine Service, Maintenance and Technical Discussion 5 03-17-2010 12:12 PM
