? Timing On 428 - Pontiac GTO Forum
post #1 of 2 (permalink) Old 09-01-2009, 07:41 PM Thread Starter
? Timing On 428
OK I have a 1968 gto 428. It has 11.2:1 Mid Street cam 46 428 heads 750 edelbrock carb malory dist Newly Rebuilt.
What Should I set the timing to at 4,226ft And idle?
Speed Demon All The Way
goatmaster428 is offline
post #2 of 2 (permalink) Old 09-02-2009, 12:17 PM
Quoted: 35 Post(s)
With your compression, you'll need 100 octane fuel, more likely 102 or higher. Base timing should be about 6 to 8 degrees BTDC. Idle in nuetral should be about 1000 rpm, maybe a shade less. If you're running 92 octane, you'll need to run your timing about 10-15 degrees retarded---about 5-10 degrees ATDC or maybe TDC (0 degrees), and it'll be a dog.
Human Verification
66 389 tripower timing noluck 1964-1974 Tempest, LeMans & GTO Engine Tuning and High Performance 7 10-27-2016 05:35 PM
Timing Chain play Joust 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 3 07-07-2009 02:15 PM
Where are the timing marks on 455 HO? clarkaim 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 2 06-19-2009 06:20 PM
428 or 455? (Do I Live Up To My Name?) Goatman455 1964-1974 Tempest, Lemans & GTO General Discussion 31 06-09-2009 03:49 PM
new timing light new question 70gto 1964-1974 Tempest, LeMans & GTO Engine Tuning and High Performance 3 04-27-2008 11:23 AM
