455 engine upgrade - heads / pistons / compression - Pontiac GTO Forum
post #1 of 5 (permalink) Old 12-05-2012, 11:08 AM Thread Starter
vera_jr's Avatar
Im looking to upgrade my engine a little. I have a 455 out of a 74 Trans Am in my 69 GTO. Looking at the codes, that is one of the smog engines that was produced in the early 70s. It states that it has a compression ratio of 7.4:1 which is obviously not great. What is the best way to obtain a 9:1 compression ratio with this engine?
New pistons? heads?
vera_jr is offline
post #2 of 5 (permalink) Old 12-05-2012, 11:38 AM
joesweeting's Avatar
I have a 455 with "96" heads and with that combo I have a 9.5 to 1 comp ratio.
Sent from my ADR6425LVW using AutoGuide.Com Free App
joesweeting is offline
post #3 of 5 (permalink) Old 12-05-2012, 11:46 AM Thread Starter
vera_jr's Avatar
where did you get the heads? any changes to the pistons?
vera_jr is offline
post #4 of 5 (permalink) Old 12-05-2012, 12:37 PM
Quoted: 31 Post(s)
Pontiacs changed compression ration with cylinder head chamber volume, not piston changes. So, a set of smaller chambered heads will get you where you want to be. I'd recommend no higher than 9:1. There is a good compression ratio calculator for Pontiacs onthe Wallace Racing website.
post #5 of 5 (permalink) Old 12-05-2012, 03:00 PM
Quoted: 29 Post(s)
The general "rule of thumb" is that compression ratio needs to be matched to the fuel --- i.e. 9.1:1 for 91 octane, 9.3:1 for 93, etc.
This is for iron heads and a relatively stock cam. Note that these aren't hard and fast limits, just guidelines. It is possible to push them some, sometimes by a lot - but you have to really know what you're doing and also be willing to invest significant time/coin in building the rest of the engine to do it. In the end, unless it's an a dedicated race motor where every last fraction of power counts, the benefit in terms of increased power usually doesn't justify the cost or the risk involved.
Human Verification
400 v8 compression with 72cc heads SPCMarty 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 7 05-10-2012 07:06 PM
Engine rebuild help 69 GTO...pistons??? Eshack80 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 4 03-07-2012 11:58 PM
Lower Compression on 48 heads and SRP pistons jtwoods4 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 7 02-08-2012 04:53 PM
High compression 455 street engine Thumpin455 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 50 05-02-2011 07:17 PM
Can '670' Heads work on a 1966 389 engine with stock pistons? Ozzie 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 10 12-27-2009 01:08 PM
