7k3 heads - Pontiac GTO Forum
post #1 of 4 (permalink) Old 10-29-2011, 01:34 AM Thread Starter
SDGoat619's Avatar
7k3 heads
I am about to pull the triger on some 7k3 heads 2.11/1.77 96cc. These heads are off a 400. The seller seems to think that putting them on a 455 should get the compression up quite a bit. I could see the reasoning behind this as I have 114cc 4x-1h heads now. Does this sound right for around 200 bucks.
Thanks as always.
Sent from my PC36100 using AutoGuide App
65 LeMans, 455,TH400, Edelbrock preformer Intake&Carb, K&N Filter, Custom Headers & Dual Exhaust W/ H pipe, 15in ralley wheels...... More to come.
SDGoat619 is offline
post #2 of 4 (permalink) Old 10-29-2011, 03:43 AM
$200.00 sounds fair for a set of 7K3's. The 7K3 heads are approx. 96cc chambers don't know what compression ratio that will give a 455 without doing some math. But the 7K3's only have 4 exhaust bolts on each side (the end bolts are not there). So getting a set of headers to seal will require either welding and tapping two bolt bosses on each head or buying a set of brackets from a place, If memory serves me I believe called Spott's. Which is the way I went on my 7K3's. I believe these are very good heads just thought you should know about the bolt hole thing, I found out after I bought mine.
68raGTOp is offline
post #3 of 4 (permalink) Old 10-31-2011, 01:13 PM Thread Starter
SDGoat619's Avatar
Thanks for that great info it saved me from a giant pain in the a$$. Needless to say I ended up not going the route of the 7K3 heads. I think that for now i have settled for the 6x-4's as they seem to be a favorite for 455 builds. Any thoughts on if its worth it to convert the exhaust valve from 1.66-1.77.
thanks as always
post #4 of 4 (permalink) Old 11-02-2011, 12:23 PM
Depends on how much you want to spend on the heads. In my opinion bigger exhaust valves are never a bad idea! I run a 400 myself, but I always thought the 455's liked the bigger combustion chambers? Like the 6X-8's, just my thought or question.
68raGTOp is offline
Human Verification
edelbrock heads or 6x heads bobby326 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 10 08-23-2010 12:40 PM
L92 heads and cam Bluegoat05 Engine Discussions 18 07-03-2010 09:09 AM
1969 RA IV Heads & 1972 HO 455 Heads for sale WARCHIEF 1964-1974 GTO parts for sale (Price & Pictures Required) 3 04-08-2009 09:12 AM
ls6 heads? bassist3453 Engine Discussions 9 07-25-2008 08:27 PM
next for me, cam? heads? v8newb 2004-2006 GTO General Discussion 1 07-19-2008 09:46 PM
