Is this a good deal on this engine? - Page 2 - Pontiac GTO Forum
post #11 of 19 (permalink) Old 12-13-2012, 11:37 AM
Quoted: 29 Post(s)
RA III's are still D-port heads, and as far as port flow goes they're all about the same. They differ in valve sizes and whether or not they have screw-in studs. They've got the same "big valves" (2.11 intake, 1.77 exhaust) as all the other big valve, screw-in stud heads, so no - in my opinion it's not worth paying a premium for RA III's over, say, a set of #62's. They aren't going to perform any better. The best factory heads for Pontiacs are going to be any of the "round port" heads. Starting with 68 1/2 Ram Air II (round port exhaust, but same intake ports as the D-port heads), then the Ram Air IV's (round port exhaust, "good" intake ports), '71 455-HO (round port exhaust, good intakes, larger chambers), and 73-4 455 SD. The 455-HO's don't flow as well as the Ram Air IV's because the larger chamber volume "squeezes" the ports and hurts flow. This problem was addressed in the 455 SD heads, generally regarded as the best flowing factory heads Pontiac made --- with the possible exception of the super-rare and never-officially-in-production Ram Air V's. (those were completely different on both the intake and exhaust side, requiring different intake and exhaust manifolds/headers to match the ports). If you're able to find any factory Pontiac round-port heads at all, get your check book out - they're going to be super expensive.
However, if what you care about is performance, then none of them perform as well as just about any of the aluminum aftermarket heads, especially if they've been ported by someone who knows what they're doing.
Also, I have to respectfully disagree with 66 Gas Tires Oil on one point. Reputable builders do use Eagle parts. That's an old wives tale that got started in part due to a comment in the first versions of Jim Hand's book. Some of the very first Eagle cranks did have a problem in the shape of the fillets on the journals, but that was corrected years ago. I'm running an Eagle rotating assembly in my engine and it's fine. In fact, it probably saved my engine when the transmission let go at the track awhile back and let the engine spin to the moon before I could reel it in. If I'd had factory rods in this engine, I'd have been out much more than the cost of a transmission rebuild.
BearGFR is online now
post #12 of 19 (permalink) Old 12-13-2012, 11:49 AM Thread Starter
Ironically, I was cleaning out my computer yesterday and I discovered I had saved an ad from Herb in the past. It was for the same engine but it was going for $3,699 as opposed to $3,999. The only difference between the two ads is the current ad has "I-beam" rods while the old ad I found had "H-beam" rods. Is there really a $300 difference between I-beam and H-beam rods?
mrvandermey is offline
post #13 of 19 (permalink) Old 12-13-2012, 01:11 PM
Quoted: 31 Post(s)
There is a price difference, but, mainly, it's inflation. I redid the entire interior on my '67 GTO convertible in 1993 for a shade over $600, and that included everything from the seat foams to the shifter indicator lens. Now, I think it would be over $2500. The longer you wait, the more expensive it's gonna be. Next time you check, it may be $4299!!!
post #14 of 19 (permalink) Old 12-13-2012, 04:18 PM Thread Starter
Well I am highly interested in this engine. Now I am looking for the cash to make an offer on one. As it turns out, my brother may be getting a barnyard-find 1966 GTO for $500. Since he owes me for buying him his project car (a 1969 Cadillac de Ville convertible), he may be paying me by giving me the 1966 GTO. If that happens, I have yet to decide whether I am going to keep the 1966 GTO or sell it so I can use the money to sink into my 1968 GTO convertible.
post #15 of 19 (permalink) Old 12-13-2012, 05:26 PM
Quoted: 31 Post(s)
My vote is to keep the '66...it's a great year and you can't have too many GTO's!!!
post #16 of 19 (permalink) Old 12-13-2012, 05:54 PM Thread Starter
I personally ! However, reality sets in. Too many projects usually means no project gets done. It is hard to spread limited funds, space and time over multiple projects and get positive results.
post #17 of 19 (permalink) Old 12-13-2012, 07:26 PM
Quoted: 31 Post(s)
How right you are. When you get ahold of the '66, post pics. If you want to sell it, I am interested!!
post #18 of 19 (permalink) Old 12-15-2012, 05:17 AM
Koppster's Avatar
Any comments on cast cranks versus forged, I thought I remembered reading about some issues.
Koppster is online now
post #19 of 19 (permalink) Old 12-15-2012, 08:38 AM
Quoted: 29 Post(s)
The legend that wouldn't die.....
Yes there were a few very early production Eagle cranks that were off in the fillets on the sides of the journals. This problem was corrected before Jim Hand's book (where the legend started) was even published but he chose to mention it anyway.
As far as cast vs. forged, a forged crank is "nice" but in a Pontiac it's not really needed until you're making 650 hp+ or spinning it past 7000 on a regular basis. I have a cast crank in my 461 - it runs high 11's.
Human Verification
A Good Deal? brown314 2004-2006 GTO General Discussion 10 05-01-2011 08:15 PM
Good deal? Itsgregfoo 2004-2006 GTO General Discussion 3 05-01-2011 03:44 AM
Think this is a good deal? BlckGTO04 2004-2006 GTO General Discussion 3 09-14-2010 09:26 AM
Looking to get a GTO. Whatís a good deal, what to look out for? Max78 2004-2006 GTO General Discussion 17 01-25-2010 10:08 AM
Is This A Good Deal Badguy23 2004-2006 GTOs for Sale (Price & Pictures Required) 12 11-10-2006 07:22 PM
