Part nomenclature - Pontiac GTO Forum
post #1 of 3 (permalink) Old 03-20-2017, 05:48 PM Thread Starter
Part nomenclature
Does anyone know what the part is called that appears to serve as a backing plate for the bolts on the flexplate where the flexplate bolts to the crank? I had to cut the heads off the bolts to get the flexplate off(heads were stripped). In the process of cutting off the heads I damaged that "backing plate". It doesn't appear in any of the diagrams I could find in the service manual. I can't really look for the part without knowing what it's called. Anyone know where I can get a new one?
NDExpat is offline
post #2 of 3 (permalink) Old 03-20-2017, 09:30 PM
Goat Roper's Avatar
Quoted: 64 Post(s)
Shim plate, flex plate then bolt plate.
You can get a bolt plate and the proper bolts here.
Transmission Parts
Goat Roper is online now
post #3 of 3 (permalink) Old 03-21-2017, 03:15 PM Thread Starter
Thanks Goat Roper. Found the part now that I know what it's called.
NDExpat is offline
Human Verification
Help! What is this part?! antoniomquesada 1964-1974 Tempest, Lemans & GTO General Discussion 2 11-07-2014 10:16 PM
what's this part???anyone,,value 2lucke4u 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 6 11-29-2009 02:57 PM
Help with a part beaudee 2004-2006 GTO General Discussion 1 11-09-2007 11:14 PM
Need part #'s ?.......... johnebgoode 2004-2006 GTO General Discussion 0 10-16-2005 05:47 PM
