Reading Date Code - Engine Id For '66 389 - Pontiac GTO Forum
post #1 of 6 (permalink) Old 05-26-2010, 07:59 PM Thread Starter
take5's Avatar
Engine is now being worked & I've attached pictures of build codes found near distributor hole. This is an original 1966 389 4 barrel car. Please advise breaking down code and what information is represented and to be found here.
Thanks for all the help as this project moves forward.
Name:	Restoration 1966 GTO - 5-26-2010 003.jpg
ID:	7542   Click image for larger version
Name:	Restoration 1966 GTO - 5-26-2010 002.jpg
ID:	7543   Click image for larger version
Name:	Restoration 1966 GTO - 5-26-2010 007.jpg
take5 is offline
post #2 of 6 (permalink) Old 05-26-2010, 08:43 PM
Quoted: 4 Post(s)
It looks like a C176 which is March 17, 1966 and was built on the night shift, the casting number is also correct for a 389, on the front of the block you will find a letter code that will tell you if the motor is original to a GTO. Also, the heads should have 093 on the center exhaust ports
The vehicle build date on the data plate may be 03C, 03D, 03E or 04A.
05GTO is offline
post #3 of 6 (permalink) Old 05-26-2010, 09:36 PM Thread Starter
take5's Avatar
Thanks Randy,
I'll check out the letter code on the front of the block for being original to GTO. By the way, what letter code would indicate GTO?
The heads do have 093 on the center exhaust ports.
Also, here is a picture of the data plate.
Name:	VIN 1966 GTO 001.jpg
ID:	7545   Click image for larger version
Name:	VIN 1966 GTO 003.jpg
take5 is offline
post #4 of 6 (permalink) Old 05-27-2010, 07:59 AM
Quoted: 4 Post(s)
WS, XS & WV are manual tri-power cars with 360hp,
YR is an automatic tri-power car with 360hp,
WT & WW are manual 4bbl cars with 335hp,
XE & YS are automatic 4bbl cars with 335hp,
The hole stamped in the bottom of the data plate to the left of "Body By Fisher" identifies the car as having a shoulder harness which was a factory-installed provision.
The original color was Nightwatch Blue with black interior and was built in the Fremont, CA plant.
05GTO is offline
post #5 of 6 (permalink) Old 05-27-2010, 07:40 PM
MaL
MaL's Avatar
Send a message via AIM to MaL
Woah, so much to learn!
I have that hole stamped also and wasn't sure what it meant. I thought I was going to install lap belts only in my post car.
What does the shoulder harness look like installed (mount points)? I don't think I've seen a pic yet.
MaL is offline
post #6 of 6 (permalink) Old 05-28-2010, 08:12 AM
Quoted: 4 Post(s)
MaL,
I'm believe the hole in the data plate was Fisher Body's way to let the assemble line workers know the car had the provision (threaded mount point) and could be equipped with the optional shoulder belt. Check your PHS to see if the shoulder belt option was ordered for your car.
05GTO is offline
Human Verification
1965 Gto data plates code and engine date alsgto 1964-1974 Tempest, LeMans & GTO Data Plate, Vin Tag and Drive Train Numbers 3 12-06-2009 06:16 PM
1965 Engine date Code ? 69classic 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 3 11-14-2009 01:30 PM
Where Is The Date Code on a '67 GTO Carb? Ozzie 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 3 11-06-2009 10:19 PM
Engine code and date discrepancy - HELP!! Mcantw 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 16 02-13-2009 10:04 PM
