Steering Gear - Pontiac GTO Forum
post #1 of 7 (permalink) Old 11-21-2012, 02:29 PM Thread Starter
EVERS3's Avatar
Steering Gear
Has anyone tried a "600 Steering Gear" in a 66 or 67 power steering car?? I ran into a guy at a local car show that claims "it'll make your old goat drive like a modern rack and pinion equipped car". Wondering if there is any truth to it and whether or not it would be worth the $600.00?
EVERS3 is offline
post #2 of 7 (permalink) Old 11-21-2012, 02:35 PM
Quoted: 31 Post(s)
Never heard of it.... if it's a power steering box, you have another option. Send your unit off to the folks at powersteering.com and have it rebuilt into a fast-ratio unit. It'll handle like gangbusters, and still be the original box. That's what I did with mine and I really like the results.
post #3 of 7 (permalink) Old 11-21-2012, 02:57 PM Thread Starter
EVERS3's Avatar
I had my unit rebuilt about six months ago and converted to fast-ratio, but the car still has a bit more play than I like. I googled the 600 steering gear and it appears you can get one from Hotchkis (they call it a Delphi 600 series power steering gear). According to their blurb " it utilizes the latest in steering technology including a rack and pinion style hydraulic valving" that eliminates any "slop and slush", no more "wondering and floating". Sounds interesting, but for $599.95 I am hoping for some real world feedback before jumping in to the pool!
EVERS3 is offline
post #4 of 7 (permalink) Old 11-21-2012, 04:06 PM
Quoted: 34 Post(s)
I have oem standard ratio gearboxes in both of mine, and there is no play in the steering at all. Tight as a new vehicle. If you have excessive play, it's usually a worn idler arm, center link, or tie rod ends. I'd check for worn front end parts, first.
post #5 of 7 (permalink) Old 11-21-2012, 09:27 PM
Or even something too obvious like the steering coupler.
Russ
russosborne is offline
post #6 of 7 (permalink) Old 11-22-2012, 08:59 AM Thread Starter
EVERS3's Avatar
Good advice, we changed out the bushings and reworked the tie rods, center link, etc. and installed a beefier sway bar at the same time we had the box rebuilt, may have missed something. Will take another look.
EVERS3 is offline
post #7 of 7 (permalink) Old 11-22-2012, 10:46 AM
Quoted: 34 Post(s)
If you have more than about an inch of free- play at the steering wheel, something is worn. And 1 inch is about maximum for that measurement, IMO.
Human Verification
Speedometer Drive Gear and Driven GEAR timmyg 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 3 05-05-2012 03:48 PM
Steering gear Box Numbers shelbee350 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 1 03-04-2012 10:37 PM
Steering gear box color Chris Holabaugh 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 13 07-30-2010 05:41 AM
65 GTo manual steering to power steering? d.reese 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 0 08-10-2009 06:51 PM
Black steering column and steering wheel (plastic) for 1968 GTO. CCLGTO 1964-1974 GTO parts for sale (Price & Pictures Required) 0 01-10-2009 08:50 PM
