67 GTO engine and engine compartment paint - Pontiac GTO Forum
post #1 of 4 (permalink) Old 01-20-2012, 01:25 PM Thread Starter
67 GTO's Avatar
Hey guys!!now that the holidays are out of the way i can finally do some work on the car. Im going to be painting most of the engine compartment/engine. First off let me ask is it okay to use a normal spray can or rattle can or does it have to be out of a air compressor with a gun for a good finish? Is there a difference? Second whats the correct matching paint for the blacks in the engine compartment and the motor? thank you in advance!The car is a 67 GTO. Albert
67 GTO is offline
post #2 of 4 (permalink) Old 01-20-2012, 04:17 PM
Rattle can will work fine as long as its properly prepped.
Black color is 60 degree black..... Eastwood sells the black under hood paint, its a satin finish. Engine color: medium blue metallic.
NAPA also sells the under hood black its made by Martin Senor paint.
Duplicolor's medium blue is a ice color, NAPA sells it. That color is hard to find at say AutoZone.
Use an etching primer on bare metal
Before I removed the motor and painted it with a compressor, I used the duplicolor medium blue metallic.... the picture provided is the motor rattle caned with duplicolor's med blue met. I painted it with it in the car. Covered everything. Used a lot of brake cleaner and degreaser. Took some time but it held up a few years before I restored it.
President: Susquehanna Valley GTO Inc.
president@svgto.com
Public Relations Coordinator: GTOAA
publicrelations@gtoaa.org
GTO JUDGE is online now
post #3 of 4 (permalink) Old 01-20-2012, 04:24 PM
Quoted: 29 Post(s)
Ratlle can paint is a little thinner so it takes more coats to get the same amount of paint film build, but you can get there either way.
post #4 of 4 (permalink) Old 01-20-2012, 08:53 PM Thread Starter
67 GTO's Avatar
thanks guys!! keep everyone updated with pics!
67 GTO is offline
Human Verification
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
engine compartment paint Logchain 1964-1974 Tempest, Lemans & GTO Paint Shop Discussions 12 12-08-2011 07:45 PM
Engine and Engine compartment paint? bigrc2 1964-1974 Tempest, Lemans & GTO Paint Shop Discussions 4 08-22-2011 09:46 PM
67 engine compartment 6tee7 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 5 02-25-2011 07:20 PM
67 engine compartment 6tee7 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 0 02-23-2011 11:11 PM
Engine compartment noise tomgrancher Service, Maintenance and Technical Discussion 1 08-13-2009 07:48 AM
