ABS Light in cold weather? - Page 2 - Pontiac GTO Forum
Pontiac GTO Pontiac GTO Forum
» Auto Insurance
Old 01-03-2013, 11:20 AM   #11 (permalink)
68OldGoat's Avatar
Lapres_3 || Had this very issue with my Cobalt SS. Turned out to be dirt-water getting into the ABS connector on the front passenger wheel hub. The little built in rubber gasket in the connector receded and allowed some crud to get into the connector. I took it apart and cleaned it, then repositioned the boot to seal better. Its a quick (low tech) check that can save some headaches... If you find dirt in a connector its probably the culprit even if the failure is intermittent... Pay attention when pulling the connectors off, if it feels gritty and scratchy then it probably has crap in it, regardless if you can see it or not.
I have also had experience with an intermittent ABS problem with an 06 Equinox. The stealership could not properly diagnose the problem so they suggested the sensor be changed for a meager $450.00. I bought the part and fixed it myself for about $138.00. After replacing the ABS right front sensor....the problem still persisted. Long story short.....it was a connector with crud in it. Cleaned out the dirt.........fixed!
Save yourself some money and do as Lapres 3 suggests. This seems to be a GM issue not just the GTO.
68OldGoat is offline   Reply With Quote
Old 01-03-2013, 01:17 PM   #12 (permalink)
Which connector is it? location?
My Youtube Channel
Supercharged (Roots) 6.0 GTO
Supercharged (Twin Screw) 3.0 NSX
Supercharged (Centrifugal) 4.3 S-10
batmans is online now   Reply With Quote
ABS warning light The intimidator Drive train, suspension, alignment and brakes. 3 07-21-2009 09:02 PM
Cycling ABS gomer_buzzcut Drive train, suspension, alignment and brakes. 3 01-13-2009 10:50 AM
Proper cold-weather start procedure ejj 2004-2006 GTO General Discussion 16 02-11-2007 10:00 PM
Cold Engine + Cold Tires = Runs like crap! Russ2005 Service, Maintenance and Technical Discussion 14 12-31-2005 12:54 PM
6M in cold weather The_Goat 2004-2006 GTO General Discussion 28 12-12-2005 12:23 AM
SEO by vBSEO 3.3.2
