check engine light--PO455 error code - Pontiac GTO Forum
post #1 of 6 (permalink) Old 01-29-2012, 04:14 PM Thread Starter
KroBeast13's Avatar
My check engine light came on in my 06 GTO with a code reading PO455. It said something about EVAC systems leak detected. I see no leak whatsoever. Can someone fill me in on what this issue is?
KroBeast13 is offline
post #2 of 6 (permalink) Old 01-29-2012, 04:24 PM
Quoted: 4 Post(s)
Check your gas cap,
What does that mean?
This indicates a fuel vapor leak or lack of purge flow in the EVAP control system. It means a large leak has been detected. The (EVAP) emission control system prevents the escape of fuel vapors from a vehicle's fuel system. Fuel vapors are routed by hoses to a charcoal canister for storage. Later, when the engine is running a purge control valve opens allowing intake vacuum to siphon the fuel vapors into the engine.
Symptoms
You likely won't notice any drivability problems.
Causes
A code p0455 most likely means one or more of the following has happened:
A loose or improperly affixed gas cap
A non-conforming gas cap (i.e. not factory/original brand)
Other leak or damaged piece in EVAP system
Possible Solutions
With a p0455, the most common repair is to:
Remove and reinstall the gas cap, clear the codes, and drive for a day and see if the codes come back.
Otherwise, replace the gas cap, and/or
Inspect the EVAP system for cuts/holes in tubes/hoses (you may hear a vacuum noise or smell fuel), repair if necessary
05GTO is online now
post #3 of 6 (permalink) Old 02-02-2012, 06:52 AM
Ehrgeiz X's Avatar
I get this code on mine every once in a while, too. I just open the gas cap, wipe it, and tighten it and it goes away. Doesn't affect driving or anything, but as stated, still check for the smell of gas or any breaks in your lines just to be safe.
Ehrgeiz X is offline
post #4 of 6 (permalink) Old 02-02-2012, 08:03 AM
HP11's Avatar
Quoted: 13 Post(s)
You probably need to replace the cap. GM issued a recall on the caps a few years back and will replace it free.
2004 Ford Ranger Edge Supercab (My daily driver)
HP11 is online now
post #5 of 6 (permalink) Old 02-03-2012, 08:09 AM
Ehrgeiz X's Avatar
I know what I'm doing tomorrow...!
post #6 of 6 (permalink) Old 02-03-2012, 08:39 AM
HP11's Avatar
Quoted: 13 Post(s)
Have them look up "TSB 07011 JULY 2007 Campaign - Fuel Filler Cap Warranty Extension". I believe that it extends the gas cap warranty to 10 years/120000 miles or something like that.
HP11 is online now
  Pontiac GTO Forum > The 2004-2006 GTO > 2004-2006 GTO General Discussion
Human Verification
Check engine light code help Black06GTO Service, Maintenance and Technical Discussion 2 12-06-2010 07:25 PM
engine light but no code ericsgixxer1000 2004-2006 GTO General Discussion 5 09-01-2010 08:23 PM
Check Engine Light? koolkam89 Service, Maintenance and Technical Discussion 6 04-19-2010 02:48 PM
Check Engine Light - K&N? Nomad 2004-2006 GTO General Discussion 9 12-31-2009 02:19 PM
engine code check. wannagofast 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 3 10-16-2008 12:45 AM
