GTO NA Build - Pontiac GTO Forum
post #1 of 1 (permalink) Old 01-08-2017, 11:39 PM Thread Starter
GTO NA Build
Hello guys. I think i have a spun bearing so needless to say i am going to pull the engine and rebuild. So that leads me to an opportunity. My goal is to rebuild the engine and keep it NA. I want to have the max amount of safe power. What i mean by safe is enough power to keep it as a DD. Enough power to have speed but not have to rebuild the engine every 50k miles. So reliable max power and keep it NA
I have a 2006 GTO manual trans with cold air intake and exhaust.
I have been doing some reading and I am going to need some help on what to pick out. Its using a t56 and i would like to keep it that way.
I have read that there are some sleeves i can use to increase the strength of the engine. The questions i have is:
How can i pull the engine? What are the steps? If there is a good write up i would love to check it out.
What type of Crank?
What type of pistons?
What type of heads? Should I port the heads I have or buy different Heads?
What type of clutch?
Will i need to upgrade the drive shaft?
I would like to buy an upgraded oil pump or bore mine out for better flow.
I am working two jobs just to do this project.
Jay Mardis is offline
  Pontiac GTO Forum > The 2004-2006 GTO > 2004-2006 GTO General Discussion
Human Verification
'67 GTO Build filthyrich 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 8 10-25-2016 12:28 PM
04 gto repair/build Thebuster 2004-2006 GTO General Discussion 2 01-02-2016 08:00 PM
my 66 GTO build vrusso1096 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 20 05-23-2014 11:57 AM
Where would the build sheet be in a 72 gto? markvit Member Introductions 3 02-28-2013 05:30 PM
65 GTO (clone) build Dunnburger 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 49 06-03-2012 04:15 PM
