Originally Posted by 87GN06GTO07IRL
Don't mess with him then. I have a 76mm on my 11 second GN. That thing might hit 9's as light as it is. A 55mm puts out 450 whp on a 2.0 so his car has to be sick.
We were talking numbers the one day, and I remember it being pretty damn low, but I can't recall exactly what it was. He does have alot of problems though. He torqued the hell out his frame because he was being a dumbass with it. He's swapping his whole engine and set up into a newer body (still around a '98 or so)
As for Seer's cut outs, there shouldn't be fitting issues since they'll be installed just behind the headers, but the only question in my mind is if your cats are in a different spot than normal due to your manifolds.
The quick and easy way to find out is find a local shop with a lift and put her in the air and take a look. Shouldn't be too hard to figure out your install spots and fitting issues from there. I've seen corvettes mount them aft of the cats in the bends that bring the pipes back towards the center of the car as they run down the center to meet the mufflers. It was a good set up, and allowed for maximum flow with the cut outs open.
Just be careful with the cutouts. I hear WOT with them open can cause some damage to your engine due to the loss of back pressure
