Plastic Skid Plate - Pontiac GTO Forum
post #1 of 32 (permalink) Old 02-23-2010, 11:34 AM Thread Starter
Plastic Skid Plate
I just changed my oil for the first time on my '05 GTO and now know there is a 20 pound metal skid plate covering everything up. Does anyone know if there is a lighter, maybe plastic, option?
vtalleyf is offline
post #2 of 32 (permalink) Old 02-23-2010, 11:58 AM
There are lots of options, you could either get a BMR skidplate (pretty much just sheet metal), an SLP skidplate (welded bars), or leave it off all together.
I've had mine off almost since the day I purchased the car. A lot of guys are going to tell you that you will need it just in case you hit something, but honestly it's very unlikely as the oil pan does not sit as far down as the K member. Even if you do strike something and mess it up (albeit unlikely), that's what comprehensive insurance is for.
Poncho Dan is offline
post #3 of 32 (permalink) Old 02-23-2010, 12:04 PM
jpalamar's Avatar
I wouldn't pay $0.01 for a light weight skid plate unless I was racing professional and weight reduction was beign taken very serious. It is just a waste of money.
I actually took a dremmel and cut noches into 2 of the bolt holes on just 1 side of the plate. Now I only have to remove 2 screws and losten the other 2 to slide it off. It make things so much easier.
Hope this helps.
04 GTO - sold
jpalamar is offline
post #4 of 32 (permalink) Old 02-23-2010, 12:04 PM
BobS's Avatar
1) While I agree it's unlikely you NEED it... I have a ding in my skidplate where it's been hit.
2) For the purposes of oil changes... remove (3) bolts, leaving one of the rears in place (but loosened a couple turns). Just swing it out of the way. No big deal.
BobS is offline
post #5 of 32 (permalink) Old 02-23-2010, 12:44 PM
HP11's Avatar
Quoted: 11 Post(s)
With the SLP skidplate, you can change the oil by just removing the filter.....
2004 Ford Ranger Edge Supercab (My daily driver)
HP11 is online now
post #6 of 32 (permalink) Old 02-23-2010, 12:49 PM
jpalamar's Avatar
Thats a pretty cool design.
04 GTO - sold
jpalamar is offline
post #7 of 32 (permalink) Old 02-23-2010, 01:56 PM Thread Starter
Great suggestions. Thanks for the help guys
vtalleyf is offline
post #8 of 32 (permalink) Old 02-23-2010, 06:22 PM
GM4life's Avatar
I know of a handfull of people that have hit the skid plate hard enough to damage it and not the oil pan. One guy accually cracked is oil pan because some chit in the road and lost oil.The oil pan is the lowest part of the car. if you drive your car on a trip and happen to crack your oil pan its not that easy of a fix. i'll keep my heavy plate on because I don't see the benefits of taking it off.
GM4life is offline
post #9 of 32 (permalink) Old 02-23-2010, 06:48 PM
Quoted: 24 Post(s)
You don't need it until you need it and then your engine is toast because you probably won' turn the car off fast enough. My skid plate has some nice nasty gouges. It's very easy to bottom out and where the K member doesn't matter. What can happen is when you turn into a driveway curb break the angle of the "hump" from the street and the angle of the car can make it bottom out right where the oil pan is. I know people that haven't used a seat belt since day one and they're fine. . . of course the day they're going to need it they're really going to need it.
post #10 of 32 (permalink) Old 02-23-2010, 07:12 PM
Nomad's Avatar
I've used it, and it appears the previous owner has had need of it too. This car sits kind of low compared to many cars I've had in the past, so I would rather keep mine in place so I don't rip the hell out of my underside.
Those that can impel you to believe absurdities, can convince you to commit atrocities.
- Voltaire
Nomad is offline
  Pontiac GTO Forum > The 2004-2006 GTO > 2004-2006 GTO General Discussion
Human Verification
Need skid plate (QUICK) vance_pounders 2004-2006 GTO Parts for Sale (Price & Pictures Required) 4 04-15-2009 10:03 PM
What do YOUR skid marks look like? WanaGTO Drive train, suspension, alignment and brakes. 10 02-05-2009 09:14 PM
Plastic Synchros? LS1Josh Drive train, suspension, alignment and brakes. 0 06-02-2008 07:53 PM
slp skid plate socal gto Drive train, suspension, alignment and brakes. 5 05-14-2006 07:47 PM
Heavy Skid Plate Thrashed 2004-2006 GTO General Discussion 16 05-23-2005 04:31 PM
