Old 03-25-2008, 05:32 PM   #1 (permalink)
lowazztruck's Avatar
PROBLEM with my gto please help
My 2004 Pontiac GTO is currently experiencing starting problems. Sometimes it starts fine and sometimes it just clicks only ONCE and is quiet. I am in the process of trouble shooting the problem and figure start at the battery so I pulled it and brought it to the local pep boys and they said its fine. Can this problem be the starter? Are there any known problems like this and if it is the starter is there a machine to test to tell me so?
Sorry for the long story thanks in advance
lowazztruck is offline   Reply With Quote
Old 03-25-2008, 06:01 PM   #2 (permalink)
andersen54981's Avatar
Auto, or manuell trans.?
andersen54981 is offline   Reply With Quote
Old 03-25-2008, 06:19 PM   #3 (permalink)
My Photos: (46)
Could be a starter. Pepboys certain there is enough juice in the battery to turn the engine over? There are places that can test the starter but you may have to take it out of the car. If it is a starter, check places in your area that can rebuild it rather than buy new or after market.
President : SVGTO Tigers
Member
GTO JUDGE is offline   Reply With Quote
Old 03-25-2008, 06:23 PM   #4 (permalink)
PDQ GTO's Avatar
My Photos: (10)
Try getting a jump start; chances are if it cranks the battery is your issue...Who knows what amount of load they put on your battery...
Originally Posted by GTO JUDGE View Post
Could be a starter. Pepboys certain there is enough juice to turn the engine over?
PDQ GTO is online now   Reply With Quote
Old 03-25-2008, 06:27 PM   #5 (permalink)
My Photos: (46)
I was thinking the same thing. Some of those professors they have working there will put a tester on it and if it reads 12-14 volts it's fine but as soon as you put a load on it, it dies.
Member
Old 03-25-2008, 06:58 PM   #6 (permalink)
The car is an auto. i did jump the car and the first 20 seconds i tried it the car didnt start after that it cranked right over
Old 03-25-2008, 07:21 PM   #7 (permalink)
PDQ GTO's Avatar
My Photos: (10)
Dead Battery my Man...I rather repalce a battery than a starter...
Old 03-25-2008, 07:28 PM   #8 (permalink)
id hate to buy a new batt and have it still do it and throw the money away and not be able to return it
Old 03-25-2008, 08:16 PM   #9 (permalink)
Moderator
My Photos: (16)
Do the new GTOs use a starter relay? If so, maybe swap it out with another relay to see if it gets better? How about neutral safety switch? Did you try to put the shifter into neutral and hit the starter when it wouldn`t start for you?
Old 03-25-2008, 08:36 PM   #10 (permalink)
fergyflyer's Avatar
Here's my thoughts. You are afraid of buying a battery and it not being the cause of the problem. Well you have a 4 year old car with the original battery. From this point forward you are on borrowed time with it anyhow. Sometime in the next year or so it's going to die and leave you stranded. Start with the battery and replace it. Keeping the old battery is just putting strain on the charging system and could end causing you to need an alternator.
Go fet an Opitma Gel battery. They are expensive, but will get you 6 good years instead of 4.
If you replace the battery and the problem keeps occuring, look to the starter. Also clean all your contacts on the grounds and such. After 4 years and a boat ride across salt water they probably need it.
fergyflyer is offline   Reply With Quote
69 Judge-need your opinions, please joeflyer 1964-1974 GTO General Discussion 11 08-03-2006 01:24 AM
Revived GTO mild on styling, hot going down road! 05GTO In the News 14 07-19-2005 07:37 AM
Pontiac GTO again flexes its muscles 05GTO In the News 5 05-06-2005 11:25 AM
GTO with an LSD problem?? twolf Service, Maintenance and Technical Discussion 3 03-28-2005 12:19 PM
Pontiac GTO Drifter - Car & Driver (Jul 04) m1das In the News 13 09-29-2004 09:11 PM
