Radio stays on? - Pontiac GTO Forum
post #1 of 13 (permalink) Old 01-29-2010, 09:44 AM Thread Starter
socalgto05's Avatar
Radio stays on?
Today I out the stock radio back in my car and then started it up just to make sure everything was ok, but when I shut the car off and pulled out the key the radio stayed on? The only way I could get it to go off completely was to push the off button and then start the car again. I dont know what could have happened and any help would be greatly appreciated. thanks
socalgto05 is offline
post #2 of 13 (permalink) Old 01-29-2010, 09:50 AM
Quoted: 12 Post(s)
Mine stays on as well until I open the door then it shuts off or after a few minutes the radio will shut itself off.
President: Susquehanna Valley GTO Inc.
president@svgto.com
Public Relations Coordinator: GTOAA
publicrelations@gtoaa.org
GTO JUDGE is online now
post #3 of 13 (permalink) Old 01-29-2010, 09:57 AM
HP11's Avatar
My radio shuts off as soon as I remove the key regardless of whether I open the door or not.
HP11 is online now
post #4 of 13 (permalink) Old 01-29-2010, 09:58 AM
jpalamar's Avatar
It might be a setting as alot of newer cars let the radio keep playing when you take the key out. Usually opening the door is the triggle to turn it off.
04 GTO - sold
jpalamar is offline
post #5 of 13 (permalink) Old 01-29-2010, 10:16 AM
Quoted: 12 Post(s)
I stand corrected.... Thats my Ram that does that. I just checked, my radio shuts off too when I pull the key.
president@svgto.com
post #6 of 13 (permalink) Old 01-29-2010, 10:20 AM
HP11's Avatar
The only audio settings I've ever seen in the personalization menu are 'Radio Display' and 'Audio Distortion Limiter'. Neither have to do with removing the key or exiting the vehicle.
HP11 is online now
post #7 of 13 (permalink) Old 01-29-2010, 01:31 PM Thread Starter
socalgto05's Avatar
Before I pulled the stock radio out the first time it would always shut off when I took the key out. and now its staying on even with the door open.
post #8 of 13 (permalink) Old 01-30-2010, 08:46 AM
I just bought mine 3 days ago (YAY)
But it did the same that night.Might be the cold freezing the grease maybe?
It stayed on for an hour then shut off, Then it unlocked the doors too.
But i fixed it by spraying WD-40 into the ignition key hole and it freed it up and its fine now.
nOObiE do0 is offline
post #9 of 13 (permalink) Old 01-30-2010, 09:16 AM
HP11's Avatar
One should never spray a flamable solution like WD-40 into an area where there are electrical components. There are other products that are safe for that.
HP11 is online now
post #10 of 13 (permalink) Old 01-30-2010, 09:24 AM
Quoted: 20 Post(s)
^Agree on the better stuff out there. WD-40 is like the worse penetrating fluid anyway, it dries out and in a day or two and your parts are right back to were it was, or even worse.
  Pontiac GTO Forum > The 2004-2006 GTO > 2004-2006 GTO General Discussion
Human Verification
No FM radio?!!? jpalamar Interior Discussions 8 12-17-2009 03:52 PM
04 radio byoficr Interior Discussions 5 11-29-2008 11:22 AM
67 radio blondie67 1964-1974 Tempest, Lemans & GTO Convertible Top, Interior, Glass and Trunk 15 06-28-2008 05:54 PM
The Radio Vanessaishername Service, Maintenance and Technical Discussion 1 09-20-2005 11:33 PM
Help with radio? tkinion 1964-1974 Tempest, Lemans & GTO Convertible Top, Interior, Glass and Trunk 8 07-25-2005 11:31 AM
